Author Topic: RM400 and DR500 150mm Front Hub.  (Read 3928 times)
« on: March 29, 2009, 08:25:24 pm »
I've got a 150mm full width Suzuki front hub. I think it is a DR500 hub. Can anyone tell if it the same hub as the RM400, or point towards a webs Suzuki parts books.
Re: RM400 and DR500 150mm Front Hub.
« Reply #1 on: March 29, 2009, 08:33:53 pm »
could be PE 250/400, RM250/400 or DR400.
has it got cut outs for a speedo drive on the brake side?
ok i did some checking and they are all the same. The hub for the RM/PE's eventually superceeds to the DR hub.  i looked up DR/SP 500 from 83 and the same hub is listed to fit the PE's and RM's
have a look around here. The SP500's in USA are the equivalent bike to the DR500 you posted. the USA DR500's were not like ours and were more like a RM/PE.
so to answer you question YES, but there could be possible differences. like the RM hub may not have cut outs for the speedo drive.
www.alpha-sports.com
« Last Edit: March 29, 2009, 08:47:06 pm by LWC3077 »
« Reply #2 on: March 29, 2009, 08:43:08 pm »
DR 500 came with 2 different front hub sizes  one had 130mm shoes the other the same size as Pe / Rm 150mm
check thru   http://www.alpha-sports.com/suzuki_parts.htm
« Last Edit: March 29, 2009, 08:49:54 pm by oldfart »
« Reply #3 on: March 29, 2009, 08:48:51 pm »
is the 130mm hub full width eg a PE 175 T/X item or half width/conical like a full foater RM/PE hub?
i have a 130mm conical type suzuki hub i havent ID'd yet. it might be a DR one.
« Last Edit: March 29, 2009, 08:50:26 pm by LWC3077 »
« Reply #4 on: March 29, 2009, 08:50:34 pm »
full width ...    yours might be off  Rm 125 b also
« Last Edit: March 29, 2009, 08:53:03 pm by oldfart »
« Reply #5 on: March 29, 2009, 08:51:28 pm »
ok so that would be same as PE 175 then?
Offline suzuki27
« Reply #6 on: March 30, 2009, 05:58:20 pm »
I am pretty sure the RM250/400 T went to a larger diameter front hub in 1980. The 250/400 N (RM) was smaller than the T. One of the few non-cosmetic changes.
« Reply #7 on: March 30, 2009, 06:06:19 pm »
i did some looking
RM250/400 T - 130 X 22 shoes
RM250/400 N - 150 X 28 shoes
thats from the SBS book
did they go smaller in 80?
« Last Edit: March 30, 2009, 06:11:31 pm by LWC3077 »
