Author Topic: Not strictly Vintage..............  (Read 5165 times)
« on: September 27, 2007, 07:35:05 pm »
Have an RMX 250(98 model) engine build on and getting the kick starter off is a real riddle
There is NO
Pinch bolt
Circlip
Retaining pin
The starter moves on the spline a little bit then stops, please help before I get the 6inch angle grinder out  >:(
Re: Not strictly Vintage..............
« Reply #1 on: September 27, 2007, 07:55:38 pm »
Hands Lozza the stick welder
 Looking on the parts fishe i can see the knuckle is held on by a centre bolt with a large head into the shaft. maybe check its the real kicker for it  or the obvious and check for damaged/bent splines
http://alpha-sports.com/smoto/1998%20RMX250/24.gif
« Last Edit: September 27, 2007, 08:07:11 pm by pokey »
« Reply #2 on: September 27, 2007, 09:50:07 pm »
Got a manual pokey and the bolt is defiantly removed.Splines look OK so it's out with the 3 jaw puller
« Reply #3 on: September 27, 2007, 10:52:16 pm »
I cant see any other physical method of securing it mate. all that tells me is perhaps a slightly worn spline thats catching. The puller could be the way to go.
 all shall be revealed when she is off. perhaps a slight turn  to the front to clear any step that has worn into it.
« Reply #4 on: September 28, 2007, 01:19:17 pm »
Just use the puller Lozza to force it off** my KTM had the same problem, the splines burr themselves over with vibrations which lets them move a little but not come off.
**if something breaks when you force it don't blame me :)
« Reply #5 on: September 29, 2007, 12:16:59 pm »
Thanks for the 'support' ther Geoff ;D Came off easy with the 3 jaw, just was taking it easy the engine isn't mine
