Author Topic: Kick starter question  (Read 1676 times)
ChrisACT
« on: March 28, 2009, 10:16:38 pm »
Does anyone have a 2001+ YZ250 that they could measure the diameter of their kick starter shaft on?  And also how many splines are on it?
I'm trying to see if a 2001+ YZ250 kick starter lever will fit onto a 1972 DT2 shaft.  I need more clearance and the recent YZ250 kick levers hang out from the frame more compared to the older style ones.
Thanks,
Chris.
Re: Kick starter question
« Reply #1 on: March 28, 2009, 10:29:28 pm »
Don't the newer levers use a nut on the end of the shaft (or a bolt into the shaft), rather than the old style pinch bolt/clamp on arrangement?
ChrisACT
« Reply #2 on: March 28, 2009, 10:49:24 pm »
D'oh!!
You're right.
Oh well, back to the drawing board then.
ChrisACT
« Reply #3 on: March 28, 2009, 11:27:21 pm »
Looks like the RZ350 kick starter might be the go.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #4 on: March 28, 2009, 11:50:16 pm »
This is what you need, the RD350 and DT2/MX250 use the same diameter shaft, spline and kickstart knuckle.
http://hvccycle.com/Kickstarter.htm
Ban BLACK rims NOW
ChrisACT
« Reply #5 on: March 29, 2009, 12:58:48 am »
Thanks for that.
Chris
