Author Topic: Help! XR80 timing chain  (Read 5945 times)
Offline ideasman
  • father of two bike loving boys
« on: March 28, 2009, 07:43:10 pm »
 Have started a resto project on a 1985 XR80 for my Son. ground up rebuild and loving it! Need help with how to replace timing chain. have all the new gear ready to go. and have head removed from bike. Where to now? can clearly see the timing chain loop around the crank. and think i will have to split crankcase. Is there a better way. If not where should I start and what should i look out for?
any and all help greatefully  accepted.
1985 XR80,1986 XR100,1986 RM80, 1984 YMF350, 1997 KTM400,1996 RM80, 2007 TTR90E, 1987 PW50.
lc4
Re: Help! XR80 timing chain
« Reply #1 on: March 28, 2009, 08:24:40 pm »
I would assume all you would have to do is remove the flywheel and then pull the chain out over the end of the crankshaft.
« Reply #2 on: March 28, 2009, 08:35:26 pm »
a workshop manual would be very handy if your having trouble ;)
Offline ideasman
« Reply #3 on: March 29, 2009, 08:28:10 am »
thanks for the advice, have removed the flywheel and stator plate, if the oil seal is removed from the crank end i may have a chance, any tricks on doing this without damaging the seal.
Offline ideasman
« Reply #4 on: March 29, 2009, 09:35:38 am »
 :) Thanks for the tip LC4, removed the seal with a pick damaged it but hey they are cheap. and removed the cam chain over the end of the crankshaft with out any swearing at all was a litle fidley getting the new one in but all up took about 5mins.
hanks for your help.
cheers, Ideasman.
Offline BETRIC
« Reply #5 on: March 29, 2009, 07:11:24 pm »
YOU WILL HAVE TO SPLIT THE CASES AS THE OIL SEAL HOLE IS NOT BIG ENOUGH TO REMOVE THE C/CHAIN, THAT ONLY WORKS ON Z50, C90 TYPE ENGINES
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
« Reply #6 on: March 30, 2009, 08:06:54 pm »
Works on SL100/125 XL100 CT125/185 CB,CL 100/125 etc etc  and about every other upright Honda single I have ever worked on and not rooted any seals ....I must have been lucky ;)
Offline ideasman
« Reply #7 on: April 03, 2009, 07:41:55 pm »
Definatley will work with XR80!!!   have Just done it!!!!!
Cheers.
