Author Topic: nice 510  (Read 13862 times)
Offline Husky500evo
Re: nice 510
« Reply #15 on: March 20, 2009, 09:21:25 am »
The trouble with those bikes is they have no oil pump, only splash feed and bottom ends don't last long. Also the ignitions are shit and fail regularly. I had one and it made an old maico look reliable
I think that the big-ends in these motors would last ok if the owners had used good oil & changed it regularly . After all, Husqvarna used this same design (with no oil pump) right up till the '96 TE610 . In Australia, it seems that many owners treated them like XR Hondas & rode them with long intervals between oil changes . I think that the guys with modern high performance fourstrokes, like YZFs,CRFs,RMZs ,KTMs & Bergs , have now realized that you have got to change oil frequently if you want them to last .  I would agree that the ignitions couldn't handle heat & failed regularly , especially on the '83 model which had the stator mounted behind the flywheel . The '84 model had the stator mounted on the cover , outside of the flywheel to try to keep it cooler , but they still were unreliable . But for VMX use , where the races are usually short , I don't think that heat build up would be a problem & the ignitions should last .
« Last Edit: March 20, 2009, 12:10:03 pm by Husky500evo »
Offline Marc.com
Re: nice 510
« Reply #16 on: March 20, 2009, 08:26:25 pm »
Except for the black rims.
knew that was coming ;D
jghusky
Re: nice 510
« Reply #17 on: March 21, 2009, 12:00:50 am »
The black rims are just beautifull.Ilove it
Offline caps 999
Re: nice 510
« Reply #18 on: March 26, 2009, 08:41:52 am »
just to be differnt i like the blue and yellow one its differnt
MUGEN power
Re: nice 510
« Reply #19 on: May 02, 2010, 07:22:08 pm »
Keep your eyes peeled for photos of a 84 TE 510,with lots of 83 bits, twin pipes out the back,white non plastic tank,purr's like a cub,...very very nice  8)
www.pre85mxwa.com
Re: nice 510
« Reply #20 on: May 03, 2010, 07:49:04 pm »
Here she is..www.pre85mxwa.com.
Collie Photos...photo number 27 .page #4
You just had to be there.  :P
