Author Topic: NEW PROJECT-IS THIS TOO FAR GONE?  (Read 6603 times)
Offline shorelinemc
  • life sucks&then you die
« on: March 16, 2009, 05:58:56 pm »
My new project mk8250 pursang  do you think this is too far gone ?it is now in bits ,frame repairs 1st in line
Offline shorelinemc
Re: NEW PROJECT-IS THIS TOO FAR GONE?
« Reply #1 on: March 16, 2009, 06:50:53 pm »
forgot the pic
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #2 on: March 16, 2009, 07:03:00 pm »
yeah, sorry Robin, it's stuffed!
i'll give ya $50 bucks for it.. :)
"flat bickie"
« Reply #3 on: March 16, 2009, 07:04:53 pm »
Nah, barely used, almost brand new. ;D ;D ;)
All Things 414
« Reply #4 on: March 16, 2009, 07:38:52 pm »
I think the beauty of these things is that you can still get nearly ANYTHING for these bikes via Bultaco Parts and the other Bully specialist around the globe...... :'(
Offline JC
« Reply #5 on: March 17, 2009, 04:24:28 pm »
IMHO just about any Pursang in any state is worth a resto!
Mark Austin
« Reply #6 on: March 17, 2009, 05:10:17 pm »
No problem - I've restored much worse than that!!!
Mark
Offline Big John
« Reply #7 on: March 18, 2009, 09:05:02 pm »
Give Peter Schoene at Bultaco parts Australia a ring, he will have or get all the bits you need. In no time you will be ripping up the track with a big smile.
Offline steve234
« Reply #8 on: March 19, 2009, 11:38:32 am »
I paid allot for a "runner" which looks the same..........yeah i know!
If you have any tips on removing the swing arm bolt please share.
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
runutz698
« Reply #9 on: March 19, 2009, 02:47:59 pm »
It would make a fine resto, if you are really worried about it I can take it off your hands. As far the swing arm bolt the answer is in the name "SWING" a heavy object thus being a hammer with a punch and away you go.
Offline shorelinemc
« Reply #10 on: March 19, 2009, 06:16:44 pm »
Pay attention here is the lesson on removing the swingarm bolt ( this is method 2 as the frame wont fit under my press) step 1get esky,step 2 fill esky with ice step 3 put at least a 6pack in step 4 whilst the beer is cooling down go to hardware shop and buy 4 good quality hack saw blades  and a milk crate if you don`t already have one ,tho all good dirt bike owners should have at least three spare at all times step 5 open beer step 6 fit new hack saw blades step 7 intake of 1st beer and then start cutting, enjoy. when the swingarm axle has been cut off both ends you then press the remander out
Offline steve234
« Reply #11 on: March 19, 2009, 06:41:20 pm »
Thanks Shoreline........this process will obviously require technical help via numerous onlookers armed with cold beer.
Bultaco M106 Astro
« Reply #12 on: March 19, 2009, 09:30:32 pm »
Shoreline nailed it pretty good except for a few errors ;D
# Replace beers with a cans of Bourbon
# Replace hacksaw with 5" grinder & thin blades.
Another helpful trick is to place a bottle jack inbetween the frame rails to slightly pry open enough room for either hacksaw blade or grinder disc to fit through.
Just spread slightly & it will flex back
And be careful when putting parts in a press, I have had to repair a few frames that had the swingarm pivot gussets on the frame crushed from too much force.
Offline shorelinemc
« Reply #13 on: March 20, 2009, 05:41:00 pm »
You are spoiling them GMC  by telling about thin discs
« Reply #14 on: March 21, 2009, 08:23:49 pm »
Sorry Shoreline, I will try to keep quit about trade secrets in future ;D
If trying to press the bolt out keep an eye on where the movement is happening so it doesn't end up ike this. I have seen a few frames damaged like this over the years.
