Author Topic: Simons forks  (Read 26963 times)
Re: Simons forks
« Reply #45 on: March 20, 2009, 11:36:45 pm »
you can put a set of emulator valves into any old set of 35-38mm  OEM forks and yeah they do help but they are not going to be the same as a set of Simons which from what i gather by comments here, also have thicker steel tubes, more travel, better matting surfaces and overall construction than a set of std OEM KYB or Showas (which were made to a price), plus you also get the bling aftermarket factor. So i guess the real good set up would be a set of cartridge emulators in a set of Simons to have the best possible set up.
« Last Edit: March 21, 2009, 12:05:00 am by LWC3077 »
Re: Simons forks
« Reply #46 on: March 20, 2009, 11:51:44 pm »
LWC you're probably right, emulators weren't available back then and they probably would make further improvement.
Offline Marc.com
Re: Simons forks
« Reply #47 on: March 21, 2009, 01:36:12 am »
cartridge emulators in the Simons is something I have already considered and will probably try. I guess the Simons forks satisfy my desire to build trick bikes in the same way as guys by NOS parrs to build new ones.
I managed to get a spy shot of the 2010, they are experimenting with leading links.
« Last Edit: March 21, 2009, 01:50:48 am by marcFX »
Offline Tahitian_Red
  • Mugen ME480
Re: Simons forks
« Reply #48 on: March 26, 2009, 09:28:08 am »
Simons forks on 1977 bike with 9" of travel are a trick setup, but they are nothing special when compared to Fox Forx, 81 Maico forks or 83 cr480 forks.  They were a higher quality set of forks to replace the flexy, sticky stock forks on most bikes of the era (1977-80).  They are basically a specialty built copy of Maico forks for other bikes.  I am still amazed Marty Moates won the 1980 500 USGP using Simons on a privateer YZ465.
You can't beat the "cool factor" of having a set on your 77 RM Suzuki or 78-79 Honda CR.  ;D
The "Factory Novice"
California, USA
Ji Gantor
Re: Simons forks
« Reply #49 on: March 26, 2009, 09:37:43 am »
Cool,
I thought they looked like Maico innards.
Ji
