Clubroom
Tech Talk
Welding Brackets to frames
Topic: Welding Brackets to frames (Read 2195 times)
XR
Novice
March 16, 2009, 12:10:31 pm »
Hi, I have a broken side number plate bracket on my RM 250T and was wondering what type of weld should be used.
I only have oxy and arc welders at home, will they do or will it need tig welding?
Regards
matcho mick
Re: Welding Brackets to frames
March 16, 2009, 01:23:52 pm »
XR ,go the oxy,try and shield all behind the flame so you don't set fire to anything else
XR
Novice
March 16, 2009, 01:46:54 pm »
Thank's Mick, Bronze or wire?
Suzukal
C-Grade
March 16, 2009, 03:20:20 pm »
Wire's stronger...
Doc
Reply #4 on:
March 16, 2009, 05:21:43 pm »
don't go bronze!..if you have to do that then break out the stick welder and give it a zap with that. Dunno about others but my pet hate is pipes and frame repaired by brazing. Unless the item was made like that it sucks when it comes to repairs or mods.
Clubroom
Tech Talk
