Author Topic: Mikuni Carby Jets  (Read 7189 times)
Offline yzhilly
  • Melbourne
Mikuni Carby Jets
« on: September 26, 2007, 11:51:36 am »
I was  trying to figure out Pilot Jet Sizes , My YZ400E lists, #60 pilot standard  .YZ125H #80 ,YZ465H #45 pilot .To richen the mixture on the pilot jet do you go a lower number jet with a larger hole ?.  Main jet   bigger # = more fuel ,bigger hole .  Pilot jet i am now confused .
Viper #436
Maico31
Re: Mikuni Carby Jets
« Reply #1 on: September 26, 2007, 12:39:35 pm »
A lower number pilot jet is a smaller hole. Pretty much all the bikes back then came out too rich with too large a pilot jet.
Offline yzhilly
  • Melbourne
« Reply #2 on: September 26, 2007, 01:05:20 pm »
Thanks for that .The massive one in the 125 have stuffed !!!.
Viper #436
« Reply #3 on: September 26, 2007, 03:53:06 pm »
little number = little fuel.
more number = more fuel
as a basic rule you will find the Muk hex jets will be a value in flow per minute , for example  a #210 main jets will flow 210 cc/min
and so on. thats what made the muk so easy to work with simple really :O)
« Last Edit: September 28, 2007, 03:17:16 pm by Freakshow »
« Reply #4 on: September 28, 2007, 03:18:00 pm »
heres a chart :O)
[attachment deleted by admin]
« Reply #5 on: September 28, 2007, 03:25:47 pm »
Mikuni Pilot Jets
VM22/210
Most Mikuni Carbs. Sizes #10 - #110.
Sizes #10 - #40 available in increments of 2.5,  and sizes  #40 - #110 in increments of 5.
 Mikuni Main Jets.
4/042 Large Hex
Fits Needle Jets 159, 166, 176, 183, 188, 192, 193, 205, 211, 224.
Sizes #50 - #200 available in increments of 5, and #200 - #500 in increments of 10,
                     and #500 - #720 in increments of 20.
« Reply #6 on: October 02, 2007, 04:01:05 pm »
i have a tunning manulal for them if that helps ya.
« Reply #7 on: October 02, 2007, 05:10:45 pm »
Beware though Freaky Mikuni claim a 10% allowable error in jet sizing ??? Also the "tweenie" aftermarket Mikuni jets can be miles out(I've never found this) but seen the effects of what happens when you get a misnumbered aftermarket jet >:(
« Reply #8 on: October 02, 2007, 07:42:18 pm »
noted LOz.
although i have a A/F in the TM right now and whatever the number may be if its not, its right :O)
Offline yzhilly
  • Melbourne
« Reply #9 on: October 03, 2007, 08:30:03 am »
Thanks for the chart Fraeky . I'm not having any drama's at the moment i was just struggling getting my head around the 125 running a # 80 pilot and  a 490 spec is a #50 as my 400 was running a tiny pilot smaller than a #50 could'nt read the number and the main was a #310. So i am running #50 pilot  #380 main and is now running sweet.
Viper #436
« Reply #10 on: October 03, 2007, 09:21:46 am »
i think it has also to do with the cylinders, transfer and all that too. and VM come in Bleed and in normal so differant carb circiutry uses differant # for volume. if it works its right, even the mikuni tuning manual says that
