Author Topic: CZ the good oil  (Read 6084 times)
Offline HL400
CZ the good oil
« on: March 10, 2009, 07:13:32 pm »
Hi CZ experts, what weight oil do I put into a 1973 CZ 400 forks. ?
also what do I use in the gear box ?
HL
Offline shortshifter
  • Sunshine Coast QLD
Re: CZ the good oil
« Reply #1 on: March 10, 2009, 08:34:46 pm »
HL couldnt find any info on fork oil weight,but I suppose personal preference has some bearing.Gearbox oil everyone has an opinion on that but Ive just changed mine and am using Motul 10004t 20w-50 which has the extreme pressure additives.The previous owner said he just used a good quality motor oil 20w-50 and another guy I know uses extreme pressure differential oil.Take your pick.
090
Re: CZ the good oil
« Reply #2 on: March 11, 2009, 12:40:28 am »
Its definitely thicker oil. 15 or 20 weight.
Offline HL400
Re: CZ the good oil
« Reply #3 on: March 11, 2009, 06:02:46 pm »
thanks shorshifter, does, 70cc sound right for each leg ?
Ian P
Re: CZ the good oil
« Reply #4 on: March 11, 2009, 07:39:53 pm »
Offline HL400
Re: CZ the good oil
« Reply #5 on: March 11, 2009, 08:19:01 pm »
Hi Ian P,  now I have different amounts my old manual says 70cc and the one on the web site says 170cc. !!!!!  HL
Offline Bamford#69
Re: CZ the good oil
« Reply #6 on: March 11, 2009, 08:55:11 pm »
Hi
I 've been using Castrol TQF ,170 ml per leg when dry and with 7 inch travel, 72 kg (wringing wet) ,the CZ riders handbook Recommends;
Transmission oil; Castrol SAE 80 ,&Shell Spirax,
I've been using  that and now Castrol EP80/90 for all my CZ's gearboxes since 1964!!
and  20 to 1 fuel/oil  , have'nt blown one up (yet)
Offline HL400
Re: CZ the good oil
« Reply #7 on: March 12, 2009, 07:10:27 pm »
Thanks Jikov, sounds like 170cc is the GO.  the gear box oil sounds a little thick, ha ha funny one.
so you SAE 80 is the go for the gear box,  HL
Offline Bamford#69
Re: CZ the good oil
« Reply #8 on: March 13, 2009, 03:37:01 pm »
Hi
If you go to the Castrol oil site and have a look at an oil called VMX80,read the tech sheet, sounds like it was just made for the job I have'nt used it, did'nt know about it ,but it sounds like the stuff, available from Supercheap ,
