Author Topic: TM125 Forks  (Read 2232 times)
Stewy138
TM125 Forks
« on: March 09, 2009, 12:57:25 pm »
Just wondering if anyone has some good tips on improving TM125 forks.  I ntoice there is no rebound spring, for example, and the springs are not progressive.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: TM125 Forks
« Reply #1 on: March 09, 2009, 01:05:30 pm »
YSS PD valves and these...
http://cgi.ebay.com/ebaymotors/Suzuki-TM125-Webco-S-W-Fork-Springs-New-FREE-SHIP-1381_W0QQcmdZViewItemQQcategoryZ10066QQihZ014QQitemZ330311991071QQrdZ1QQsspagenameZWDVW
will take you in the right direction or you could fit a TS/TF 125/185 inline axle front fork set as they are 33mm as opposed to the TM's 30 and look close to identical externally to the TM's
Ban BLACK rims NOW
TM BILL
Re: TM125 Forks
« Reply #2 on: March 09, 2009, 09:44:03 pm »
Fit TM 250 /400 L or M forks  :)
Re: TM125 Forks
« Reply #3 on: March 09, 2009, 10:23:34 pm »
i think you will find that the 33mm TS forks are only on the leading axle models from about 79 onwards
Doc
Re: TM125 Forks
« Reply #4 on: March 11, 2009, 10:56:43 pm »
yep I'm with Bill, replace your clamps with TM250 items or have your 125 clamps reamed out to 35mm and the options available multiply 10 fold. I run TM250 lowers with mid 80's DR250 internals and another has XL250 honda forks and both work a whole lot better than the 30mm spaghetti forks they came with ;) a little note also, RM80's had 30mm forks, though a little longer the lowers swap over but unsure of performance as I never ridden the bike that has them fitted :-\
« Last Edit: March 11, 2009, 11:03:35 pm by Doc »
Offline cyclegod
  • Sunny PERTH W.A
Re: TM125 Forks
« Reply #5 on: March 11, 2009, 11:02:16 pm »
I agree but not on TF ag bikes ;)
Ban BLACK rims NOW
Stewy138
Re: TM125 Forks
« Reply #6 on: March 18, 2009, 08:40:08 am »
Ok thanks guys.  Yeah I was quite surprised when I pulled the TM forks apart - thought the tiny spring was some kind of 'primary' and looked down the tube for the 'secondary' spring which of course wasnt there.  The damper rods would make some kind of neat drinking straws I reckon  :D
