Author Topic: PE Z taillight  (Read 5000 times)
Offline frostype400
PE Z taillight
« on: March 03, 2009, 08:27:01 pm »
desperatley wanted a 82 suzuki pe z tail light thanks Michael. :)
1971 tm400 and PE's
Re: PE Z taillight
« Reply #1 on: March 03, 2009, 08:33:34 pm »
times that by 2. ;D i will put a photo up here so you know what we are looking for
these pics should be good enough. i have plenty more to use for verification if needed though
yeah it looks the same as TS185ER, but the part numbers are different. i think its just the shape of the bracket thats different to suit the larger curve of the PE fender but the TS fender is more flat. Even the lens/light assembly is different to the TS, but im not sure why.
French X models and UK 175 Z models also had this light.
« Last Edit: March 03, 2009, 08:53:49 pm by LWC3077 »
Offline frostype400
Re: PE Z taillight
« Reply #2 on: March 03, 2009, 08:36:43 pm »
good Leith if anyone else needs one or has one post here or pm someone here thanks Michael. ;D
1971 tm400 and PE's
Re: PE Z taillight
« Reply #3 on: March 03, 2009, 08:51:56 pm »
there must be heaps of these somewhere stashed in peoples sheds because all Australian model 82-84 175 full floaters had this light too.
If we can find at least one i will get it drawn up in CAD so they can be made from sheet metal.
« Last Edit: March 03, 2009, 09:00:22 pm by LWC3077 »
albrid-3
Re: PE Z taillight
« Reply #4 on: March 03, 2009, 08:56:31 pm »
Michael call Ken Wilkshire at Lang bike wrechers in victoria, he has been around for a long time, he may have one in stock.
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: PE Z taillight
« Reply #5 on: March 03, 2009, 09:08:50 pm »
PE400Z taillight is 35720-40650  for E24 (Australia)  quite a different / huge / ugly beast!!
what the heck is/was a 406 model? some LTV thing? if we knew that, maybe we could source one.
the other usual one for PE400Z are E1 (general) and E6 (South Africa)
E1 and 35720-40500 and E6 35710-40513
are taillight only and taillight+stop repectively.
I don't have any photos of the E24 PE400Z tail :-(
Just put the Parts Catalogue scan of that page up onto my Pure Enduro Skydrive under PE400Z.
http://cid-407d7ef0965d3991.skydrive.live.com/browse.aspx/Pure%20Enduro
Re: PE Z taillight
« Reply #6 on: March 03, 2009, 09:11:27 pm »
whats the 406 mean? where is that written?
the normal Z market lights were the same rubber ones as the 81 X
http://cid-407d7ef0965d3991.skydrive.live.com/self.aspx/Pure%20Enduro/PE400Z/PE400Z%7C_E24a.jpg
this is what the E24 (australian) model had
i actually do have some photos of E24 PE400 Z. in the ownwers manual in B/W
« Last Edit: March 03, 2009, 09:15:23 pm by LWC3077 »
Offline lukeb1961
    • PE175N
Re: PE Z taillight
« Reply #7 on: March 03, 2009, 09:12:18 pm »
you are correct! Just prompted me to look at the PE175E parts catalogue and YES, it is the same item.
Now I did happen to get the PE175E Owners Manual today...
let me see if it has any photos of said tail-light.
Offline frostype400
Re: PE Z taillight
« Reply #8 on: March 03, 2009, 09:13:49 pm »
looks a bit like a cross between some mutated ts and and a xt/tt500 taillight why couldnt they have just stuck with the t and x light ;D
1971 tm400 and PE's
Re: PE Z taillight
« Reply #9 on: March 03, 2009, 09:19:08 pm »
i saw one on france ebay a while back but ran out of time to organise bidding on it when it was a ship to france only and no paypal auction which made it hard. Yeah it does look similar to XT 500. They clearly would have started with a TS 185/250ER tail light bracket and modified it from there. I will look at my 185 bracket to see if there is clearly just one major difference. it could just be one different bracket spot welded to another.
the reason for the big tail light was because of tightening ADR rules. the bigger light for visibilty, clear number plate light and to have a brighter globe. if you but a brighter globe in the rubber lights the lens melts!. got one in the mail today and the lens was melted in the center from the extra heat. Dont know wht they didnt fit a decent headlight to the front while they were at it instead of the pissy 15/15watt candle ::)
Michael, dont go mounting one of these lights to your fender until you get that little bracket that goes over the frame loop ( see above photo) and also you need the big metal brace that goes under the fender to support the heavier metal tail light.
« Last Edit: March 03, 2009, 09:29:28 pm by LWC3077 »
Offline frostype400
Re: PE Z taillight
« Reply #10 on: March 03, 2009, 09:24:07 pm »
maybe one could be made that would help us
1971 tm400 and PE's
Re: PE Z taillight
« Reply #11 on: March 03, 2009, 09:27:12 pm »
need one to copy though. no point just guessing otherwise you may as well just stick something else on. thats what pisses me off with repro parts. you either make it exact as original coping an original otherwise why bother just getting it half right.
Offline holeshot buddy
  • sunshine coast qld
Re: PE Z taillight
« Reply #12 on: March 03, 2009, 09:29:15 pm »
next time i am in the wreckers were i
used too work i will go through tailights
lots of that stuff still there if i find one
i will send it down, the frame has the loop bracket on it
but no metal plate underneath will look for that too ;D ;D ;)
follow me to first turn
Offline frostype400
Re: PE Z taillight
« Reply #13 on: March 03, 2009, 09:41:42 pm »
Thanks alot Russell need rear fenders too full length originals any pe gear wanted. :)
1971 tm400 and PE's
