Author Topic: polishing red tanks  (Read 6800 times)
Offline caps 999
polishing red tanks
« on: March 03, 2009, 12:03:55 pm »
im about to start polishing my cr tank has anyon got a process ot do red tanks ive done white ones before but colours ive got no idea
MUGEN power
Offline frostype400
Re: polishing red tanks
« Reply #1 on: March 03, 2009, 12:20:04 pm »
Ask Leith LWC3077 he will definetey know how to do that thanks Michael. :)
1971 tm400 and PE's
« Reply #2 on: March 03, 2009, 12:44:29 pm »
just do what you did on the white one. no real special methods required since its coloured.
Offline caps 999
« Reply #3 on: March 03, 2009, 01:04:33 pm »
i really just wanna know how do i get that shinny clean final finish
MUGEN power
Offline caps 999
« Reply #4 on: March 03, 2009, 01:05:13 pm »
i get to about 2000 grit with the paper but what do i do next
MUGEN power
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #5 on: March 03, 2009, 01:18:21 pm »
Brasso
Ban BLACK rims NOW
« Reply #6 on: March 03, 2009, 02:19:25 pm »
see if you can find a place that sells Meguiars - they actually go out to a 4000 grit sandpaper which is excellent for finishing.
Rossco
« Reply #7 on: March 03, 2009, 04:19:43 pm »
elbow grease ,,,,,,,,good arm pump training  ;D
alison
« Reply #8 on: March 03, 2009, 05:07:46 pm »
try wet and dry paper and Jif on polishing mop in an electric drill. if you want even more glossier than what the Jif does, use Meguiars Scratch X polish.
« Last Edit: March 03, 2009, 05:09:42 pm by LWC3077 »
« Reply #9 on: March 03, 2009, 07:57:55 pm »
Meguiars also now have a specific plastic polish available.
Rossco
zman
« Reply #10 on: March 03, 2009, 08:08:10 pm »
dont use jiff i tried it on my rm tank and had to scrape it off because it wouldnt sand out i reckon jiff is only good for white tanks
Offline holeshot buddy
  • sunshine coast qld
« Reply #11 on: March 03, 2009, 08:12:37 pm »
T cut have coloured polish
they have a red it works unreal
rub it in and buff off
fills all scratches and chips and hides marks
definately worth trying
should get it in super cheap auto or ripco ;D
follow me to first turn
« Reply #12 on: March 03, 2009, 08:16:05 pm »
you use the Jif after sanding as a polish. you dont sand the Jif. myself and others have found that Jif works really well on that period Suzuki plastic, not sure why it hasnt worked for you?
Offline DJRacing
  • YZ125X
« Reply #13 on: March 03, 2009, 08:28:33 pm »
To give the tank a shine I use a soft open mop on my bench grinder and buy the blue coloured soap which is for plastics(not the white one which is for aluminium). Please be very careful and do this process very slowly and do not press at all but just let the tank touch the mop as it is spinning. It is time consuming but well worth while. Practice on an old plastic tank because it is easy to burn/scuff. Use a new mop, not your old aluminium polishing mop unless you want your tank dark grey.
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #14 on: March 03, 2009, 09:32:21 pm »
I used it too and to my amazement it worked like a champ!
