Author Topic: KX500 1984 rear shock  (Read 3404 times)
bjays
« on: March 02, 2009, 10:06:03 am »
hi does anyone know if a 1985 kx500 shock will fit my 1984,seem to be damn close in length just wondering if there is anything tricky to consider eg fitment before i go ahead and get it shipped to me,any help much apreciated
Offline BAHNZY
Re: KX500 1984 rear shock
« Reply #1 on: March 02, 2009, 08:47:52 pm »
Way to much modifying. The 83/84 used a remote reservoir attached by a hose. The 85 has the reservoir cast as part of the shock.
Rod (BAHNZY) Bahn
« Reply #2 on: March 02, 2009, 09:05:54 pm »
you need one with an end something like this
« Last Edit: March 02, 2009, 09:14:40 pm by LWC3077 »
bjays
« Reply #3 on: March 02, 2009, 09:10:55 pm »
Thanks everyone for the help i mite just hold off on that purchase
Offline holeshot buddy
  • sunshine coast qld
« Reply #4 on: March 02, 2009, 09:22:27 pm »
1985 has remote reservoir with high
and low speed comp adj
that should be ok 8)
not sure on length or mounts
will look at my 85 500 and my 83 500 tomorow
and check ;)
follow me to first turn
« Reply #5 on: March 02, 2009, 09:36:58 pm »
ebay -  260369239036
Offline BAHNZY
« Reply #6 on: March 03, 2009, 08:03:59 pm »
I'm way off the pace. It must be the 86 that has the reservoir cast into the top housing, not the 85.
What i do know is the 83 & 84 use an inverted shock with the reservoir line coming away from the "bottom" of the shock to a canister that is mounted to the frame beside the kickstarter. This is done because there is bugger all room between the exhaust pipe and the aircleaner to mount a fixed type reservoir. Would need to confer with the suspension guru's but i dont think a conventional shock mounted upside down will work as intended, perhaps it does, i dont know. Thanks to a fellow forum member (E74) i have an ex KTM ohlins unit that i am working on from around the same vintage in an atempt at modifying to fit. Looking good so far.
Rod (BAHNZY) Bahn
