Poll
twin class
what is this
0 (0%)
stuff
0 (0%)
Total Members Voted: 0
Author Topic: broadford flat trackers  (Read 13381 times)
Offline 52
« on: February 23, 2009, 04:10:54 pm »
Is the April meet at Broadford running a class for twins.Are they organising races? I have (with help ) built an XS650 based bike to replace my Honda and would like to give it a run but if no races are organised it may be a waste of time.Firko will be glad to hear it has been put together using pre-70 parts so eligible for same. I plan to take it to DT nats later in year - may prove unusable, we will see.
Offline steve234
Re: broadford flat trackers
« Reply #1 on: February 23, 2009, 04:42:10 pm »
Have you got any pics 52?
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline pancho
« Reply #2 on: February 23, 2009, 05:53:43 pm »
 i rode herb conlons pre 70 xs650 last year in a couple of races at nepean when my bike was out of action and i found it handled ok as long as i remembered i was just a passenger on the monster!. allan attard handles herbs other xs650 really well but he's a muscular lad. i believe fitting a 21 on the front makes things easier cheers wally.
« Reply #3 on: February 23, 2009, 11:35:47 pm »
650 ?   ;) pete  ;D
Offline 52
« Reply #4 on: February 24, 2009, 03:34:00 pm »
yep, will post picture nxt wk. tank getting painted. looking for somewhere to ride it. motor has a lot of monies spent-hope it doesn't go the same way as the XL, just sent cam away this wk-took me til now to face it.
Offline 52
« Reply #5 on: February 24, 2009, 03:37:01 pm »
Wally, will you talk to Herb about gearing he has used and how hot the mtr was, thanks peter lee
Offline Grasy 6
« Reply #6 on: February 24, 2009, 07:08:19 pm »
I would probably think just park the big thing and look at it pete to save the frustration. How on earth are you going to stop the monster. Golden Wheels series at Griffth Pines Speedway on the 21 st March bring it there big run off area at the end of the straight  ;D
« Reply #7 on: February 24, 2009, 11:11:35 pm »
Be fine pete even to a 750 kit it wont go the same way as the xl, not enough revs to get the same bounce.
My money is on leaving the motor on the cool side and tuning that frame in. ;)
« Last Edit: February 24, 2009, 11:13:36 pm by Freakshow »
Offline 52
« Reply #8 on: February 26, 2009, 08:55:12 pm »
A bit late to build cool mtr kerry, already over 750, rephased,cammed,ported,high comp,36 mikunis on fuel,ect. Anyone that out-gates it better watch out its gunna take some stopping when wound up. Interesting reading the US flat-track frame discussion. In the mid 70's when a few turned up here it was and always will be the calibre of the rider that mattered (chris kelly would thown a Tm400 sideways and made it look easy).seeya
« Reply #9 on: February 27, 2009, 10:56:50 am »
GEe Pete your never one to stuff about are you.  Sounds great, i looked at building up a show trackmaster XS a while back but most of the bits i needed  where in florida and transporting never got it to work, since found some of the bits and contacts i wanted to make the project interesting enough to start, like the trick side cases and other worksy stuff. ;)
One thing i do remember was the only down side they US guys made on the XS was the stock diameter of the flywheel, those that overcame that got traction and outstomped the XR's, if they sat on the small spinner they couldnt get the tourque to the ground.  might be somthing to follow up.   On a big track you would be unstoppable.   Good choice.   You going for the full glass ? or are you on the stock frame ?
i know your sorted but if you need bits out the Us give us a yell i had some contacts that  build XS and seem to hord all the parts and knowledge, bitches  ;D
send me some pic's !
« Last Edit: February 27, 2009, 11:36:38 am by Freakshow »
Offline 52
« Reply #10 on: February 27, 2009, 05:07:17 pm »
thanks 52X , a mate of mine built the bike up using the dimentions of my 350 twin.He used XS1 frame changed triple trees and swing arm and altered rear section.He and I have had XS's forever and have collected a fair bit of stuff. The rephase of the engine hopefully will help with traction (it's effectively a V-twin now) we have done our roadies, they sound neat.No its not gunna looklike a US style flat - tracker.I didn't go that way cause unless you use 19'' front it never looks right.My son might figure out how to put picture on.
« Reply #11 on: March 02, 2009, 12:34:42 pm »
Go on you, you original 52,  :D
you know you want to be all glaaasssssssssssss
(ooh and sexy cases too see below)  ;)
« Last Edit: March 02, 2009, 12:38:11 pm by Freakshow »
« Reply #12 on: March 03, 2009, 07:02:12 pm »
52 bike
Offline 52
« Reply #13 on: March 08, 2009, 08:39:25 pm »
Fired it up today ,  pulls like a runaway locomotive. Jim tell Allan shes running. Take it to the ''Pines'' next weekend and jet.
Offline Grasy 6
« Reply #14 on: March 08, 2009, 09:01:07 pm »
Hi Pete after riding the monster today ,The Watts Special  is a tractor on steroids sounds great & feels STRONGER then Mick Tyson . Ya just gotta hang on an try an smile job well done. That is sum serious HP. But i still can't figure out how ya r will stop it ?  God help the bloke who tries to go round you on the outside. Look out Flying Jack Stevens at Townsville. Hope he has got some tear offs cause he will need em. ;D
