Author Topic: VMX247 XL350  (Read 96115 times)
Offline sudman
Re: VMX247 XL350
« Reply #90 on: August 30, 2010, 02:50:02 pm »
 8) Very cool looking track, nice power slide.
Re: VMX247 XL350
« Reply #91 on: September 25, 2010, 04:42:46 pm »
The much needed rebuild has begun today  8)
Re: VMX247 XL350
« Reply #92 on: September 25, 2010, 04:52:13 pm »
The bike or Steve  ;D
Re: VMX247 XL350
« Reply #93 on: September 25, 2010, 05:01:57 pm »
The bike.. ;D   cause if our young bloke gets on it again its going to need it all.. :P
Offline sudman
Re: VMX247 XL350
« Reply #94 on: October 05, 2011, 06:34:02 pm »
Steve will just have to come over and ride one of my C & J's to get his XL fix. ;D
albrid-3
Re: VMX247 XL350
« Reply #95 on: October 07, 2011, 08:41:19 pm »
This will be my new mount for next year scrambles, I was thinking about using a different frame, but I am not sure whether to go down that road.
Offline sudman
Re: VMX247 XL350
« Reply #96 on: October 11, 2011, 07:26:19 am »
Finding one to suit is the biggest problem, Husky frames are the best option as the motor fits without having to cut the frame. If it was me I would stay with the old XL frame I raced one to a win in Kiwivmx 2 years ago, just work on getting the weight down, drill axles, replace the steel wheel spacers with alloy, cut all the unneed tags off the frame etc.
« Last Edit: October 11, 2011, 07:32:03 am by sudman »
albrid-3
Re: VMX247 XL350
« Reply #97 on: October 11, 2011, 09:01:21 pm »
I am keeping an open mine, you may be right sudman.
Neilios
Re: VMX247 XL350
« Reply #98 on: October 27, 2011, 05:37:16 am »
Hello, VMX247 can you tell me how you manage to fit an XR400 piston into the XL350 as the gudgen pins on the pistons I have are different diameters. Thanks Neil
Re: VMX247 XL350
« Reply #99 on: October 28, 2011, 01:19:53 pm »
Neil
Strange you have a difference. The piston I use is XR400R / TRX400EX - 96 to 06.
I have not had a difference in gudgeon pin diameters.
The XR piston is a bit shorter in crown height than other pistons guys have used but thats all.
Otherwise I can t advise otherwise...... It is a sideport XL?
Steven
Offline Davy123
Re: VMX247 XL350
« Reply #100 on: October 28, 2011, 05:00:16 pm »
neil...use an xr 350 piston same gudgeon pin and 84mm - 86mm bore wiseco
Neilios
Re: VMX247 XL350
« Reply #101 on: October 28, 2011, 08:30:36 pm »
What year XR350 Davy?
Offline Davy123
Re: VMX247 XL350
« Reply #102 on: October 29, 2011, 02:48:49 am »
83-85.. think they only made it in those years
Neilios
Re: VMX247 XL350
« Reply #103 on: October 29, 2011, 06:44:17 am »
Thanks Davy, been doing some research, the XR400 piston has a 20mm pin and the XR350r and XL350 pins are 21mm, I will keep you updated. Thanks
Offline gorby
Re: VMX247 XL350
« Reply #104 on: October 29, 2011, 07:15:31 pm »
I have used the XR piston....it is bigger in the bore but a little shorter in the hieght between the pin and the piston top which leaves it a couple of mm below the top of the bore at TDC.
The extra bore size must nearly make up for the lower piston hieght.
I ground a groove in the top of the piston to replicate the original one for the inlet valve clearance
This setup worked for a couple of years hard racing for me and as far as I know it is still working for its present owner
