Author Topic: TM250L- Nats Project  (Read 88571 times)
Re: TM250L- Nats Project
« Reply #60 on: February 14, 2010, 03:25:48 pm »
« Reply #61 on: February 14, 2010, 03:53:07 pm »
I dont remember you having hairy arms Ali, what are they putting in the water over there? ;D
Offline GD66
« Reply #62 on: February 14, 2010, 05:23:16 pm »
That's her drinking arm... :D
« Reply #64 on: February 14, 2010, 07:38:29 pm »
Pm sent
« Reply #65 on: February 15, 2010, 10:52:57 am »
bitch
Would that 125 tank fit a TS185?  (circa '73)
Don't know ask Doc
Pm sent
pm sent
SOLD before the ink was dry thanks all.
Offline halo1963
« Reply #67 on: April 06, 2010, 10:42:49 pm »
Most bike shops have after market ones that fit and Suzuki still sold originals last time I checked.
Regards
Halo1963
DR
« Reply #68 on: April 07, 2010, 07:03:54 am »
Dodgee had issues getting the brake cable for his TM250 not long ago also Alison, had to source it from the US as there was little to nothing to be had locally. Cost was $35US + shipping (about $50au delivered) :-\
http://cgi.ebay.com/ebaymotors/SUZUKI-NOS-CABLE-ASSY-FRNT-BRAKE-58100-16500_W0QQcmdZViewItemQQhashZitem334710f507QQitemZ220235625735QQptZMotorcyclesQ5fPartsQ5fAccessories
« Reply #69 on: July 06, 2010, 10:42:10 am »
Time flys when ya havin fun  ;D .its been 17 months since the TM got put up on the table and its nearly complete for Wandering and 15th Anniversary,though are looking for a............
air inlet pipe between the airbox and the carby for a 74 TM 250
Many thanks
Steven Melvin
We sure don't, not aware of anyone reproducing them.
Thank you for your interest in our products.
 Please  view our website at www.vintage-suzuki.com  for our latest updates.
  We appreciate your business.
Thanks,
Tony Boswell
www.ceetracing.com
did find this info on the forum  ;D
John, did you end up finding a close match for your airbox to carb boot ? I have mentioned in the tech talk section a while back , that the junction rubber on a toilet between the delivery pipe & the bowl might work in some situations like this . I can think of no better source for a part for a Harley, than something off a toilet  Grin. The toilet delivery pipe measures around 52mm( I think it would easily stretch to 55mm) & the porcelain bowl inlet measures around 80mm ( although I think the rubber is stretched about 10mm to go over it). The junction rubber is only about 60mm long though , making it 25mm too short . You could easily extend either end , by using a small piece of stainless exhaust tube as a coupling & 25mm of radiator hose (just means that you would have 4 hose clamps in there instead of 2) .    ;D
cheers and thanks for any input Alison and Steven WA
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #70 on: July 06, 2010, 10:48:51 am »
This was a problem for me on my TMS185 project and I solved it with a 100mm section of 57mm I.D straight silicon hose (one of those pieces you see connecting turbo intercoolers etc)
Ban BLACK rims NOW
« Reply #71 on: July 06, 2010, 01:48:58 pm »
CG - thats a good idea.  Steve also check out the Sudco catalogue as they carry absolutely shiteloads of varying carby connectors/pipes/manifolds etc etc etc - even found a NOS one to mount up to a CR250 with a GEM conversion??
Rossco
« Reply #72 on: July 06, 2010, 04:07:32 pm »
just make sure its soft enough to roll back or squish up or you will do your narna every time you want to mess with the carby.     >:(
There is nothing mor frustrating then trying to fit a Hardened rubber between to points.  I prity sure i came close to tears the last time it happend, push on one ...push..... pullll..push arrrgh fecking thing go on...... :'(
« Last Edit: July 06, 2010, 04:28:38 pm by Freakshow »
DR
« Reply #73 on: July 06, 2010, 04:29:01 pm »
pop out the 2 or 3 airbox mounting screws and element, move it all back a little and fit the airbox rubber beforehand..sometimes it's easier and saves a lot of cursing. When working on the bike at the track I loosen off the clamps, remove the slide and simply turn the carb on it's side for internal adjustments rather than removing it completely ;)
« Reply #74 on: July 11, 2010, 03:16:01 pm »
will a PE or TS 125 fit ??
I'm ebay searchin and Stevens out wiring up MX kitchen  ;D
cheers Alison
