Marque Remarks
Suzuki
plastic tank resto
Topic: plastic tank resto (Read 2964 times)
zman
plastic tank resto
February 17, 2009, 06:12:05 pm »
gday ihave an rm tank that has the usual petrol and discolored look so whats the best way to get it back to the bright yellow again i tried soaking it in bleach over night but it didnt work that well cheers
RM Ted
C-Grade
Re: plastic tank resto
February 17, 2009, 06:16:11 pm »
A LIGHT SAND, THEN USE 800 OR HIGHER WET AND DRY. POLISH WITH JIF OR BUDDY. WORKS FOR ME.
1978 rm 125 x 3
1981 rm 125
1987 rm 125
LWC82PE
Superstar
February 17, 2009, 06:47:10 pm »
Welcome zman. This has been discussed a fair bit already in 'tech talk' or maybe 'bike talk' You should be able to find some useful info there or issue 33 of VMX.
http://cgi.ebay.com.au/VMX-Vintage-Motocross-Dirt-Bike-Magazine-Issue-33_W0QQitemZ110262913744QQcmdZViewItemQQptZAU_Clothing_Merchandise_Media
In short you sand and then polish, but depending how bad it is to start with you might need to start with scaping some layers of plastic off with a blade. If its stained dont expect or hope to get it all out because you most likely wont be able to. If you need a better tank for a concourse resto then look for a better tank to start off with. Its all time and elbow grease.
Last Edit: February 17, 2009, 07:08:01 pm by LWC3077
zman
February 17, 2009, 06:56:06 pm »
yeah its not to bad just discolored ive done yz tanks there not to bad but been yellow i just thought there was a different way to go about it
LWC82PE
Superstar
Reply #4 on:
February 17, 2009, 07:03:13 pm »
not really. I have heard people dry bleaching on white tanks but say its not good for coloured tanks, but i have also known people that siad bleaching a white tank didnt work for them either. if you go to the tech talk section here
http://ozvmx.com/community/index.php?topic=4749.0
you will find some discussion about UV treatment. i dont know much about that though. Apparantly a place in USA does it, but i think its only for white tanks aswell.
theres no real quick easy fix other than to get a new tank
Clarke in USA make brand new yellow RM tanks.
http://www.clarkemfg.com/cgi-bin/miva?Merchant2/merchant.mv+Screen=PROD&Store_Code=CM&Product_Code=11347&Category_Code=suzuki
BTW yellow suzuki plastics respond very well to Jif
Last Edit: February 17, 2009, 07:09:08 pm by LWC3077
lukeb1961
PE175N, RM80B, JR50C
Reply #5 on:
February 17, 2009, 07:10:36 pm »
elbow grease...
http://members.optusnet.com.au/pe175n/Plastics/Tank_AU.html
zman
Reply #6 on:
February 17, 2009, 11:15:35 pm »
ok looks like i have to go do some sanding thanks for your help i will post a pic when ive finished the bike whitch isnt far away. at last
Marque Remarks
Suzuki
plastic tank resto
