Author Topic: Removing CZ Head Bearing Cups  (Read 2388 times)
Ji Gantor
« on: February 17, 2009, 08:48:20 am »
To remove the CZ head bearing cups use a Toledo part No 246300 Split Collet Puller slide hammer with a 30mm collet.
Ji
Ji Gantor
Re: Removing CZ Head Bearing Cups
« Reply #1 on: February 18, 2009, 12:04:14 pm »
The head bearings are the old type with 16 (I think) loose S/S balls. So when you pull the steering apart the balls go everywhere.
This can now be changed to a tapered needle roller bearing system. These bearings are the same size as the original CZ bearings.
Ji
« Last Edit: February 18, 2009, 12:15:02 pm by Ji Gantor »
