Author Topic: Help to ID Yammy Forks.  (Read 3711 times)
« on: February 16, 2009, 10:08:24 am »
Can anyone positively ID these forks. I think they are IT175 - 36mm.
Offline Viper666
    • Ballarat Rovers MCC
Re: Help to ID Yammy Forks.
« Reply #1 on: February 16, 2009, 11:33:44 am »
Without length measurements I am guessing YZ125D/E, IT175F and various DT125's & 175's. If they are original then they are probably IT175F but many parts are interchangable so if the original ones were rooted then YZ125D/E would bolt straight in but had air caps but may have been replaced.
Viper666
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #2 on: February 16, 2009, 11:50:05 am »
i think the DT125/175s have 32mm stauntions. so i'd count them out if yours are 36mm.
"flat bickie"
« Reply #3 on: February 16, 2009, 12:21:21 pm »
Length 925mm extended and 725 compressed, approximate (within about 5mm) allowing for aftermarket caps.
From what I can make out, by appearance they could be E,F,G,or H. I'm assuming they have 200mm of travel. Does that help anyone to ID?
« Reply #4 on: February 16, 2009, 01:10:00 pm »
I am quite certain they are 79-81 TT 500 or 80-81 XT 500, with Goki air caps.
« Last Edit: February 16, 2009, 01:12:01 pm by LWC3077 »
« Reply #5 on: February 16, 2009, 01:14:00 pm »
i reckon they are 79-81 TT 500 or 80-81 XT 500, with Goki air caps.
The Goki air caps is right but I don't think they're XT or TT because of the Headlight Holders which I believe are original.
« Reply #6 on: February 16, 2009, 01:22:25 pm »
Im not sure exact years but those forks were the same as on IT and TT/XT for a few years anyway. I think the XT headlight brackets were rubber mounted? did the early IT's have brackets like that?. just have to wait and see until a knowledgeable 500 owner such as CJ drops in. Ignoring the brackets i still think they are late model XT/TT
« Reply #7 on: February 16, 2009, 05:44:55 pm »
the headlight ears are off 1979 it400f same as the set i had on mine
« Reply #8 on: February 16, 2009, 10:10:27 pm »
NOT YZ125D/E. The web above the axle is too short.
Fork boots suggest IT175G.
« Reply #9 on: February 16, 2009, 10:10:44 pm »
I would have thought the 'ears', and many other bits, would be common to all IT's. What size forks were the 400's? 36mm?
« Reply #10 on: February 16, 2009, 10:15:55 pm »
All IT's worn boots didn't they?
« Reply #11 on: February 17, 2009, 06:00:05 am »
I think I found the answer, at approximately 200mm of travel, its probably off an 'f' (195mm). Whatcha reckon!!
« Reply #12 on: February 17, 2009, 08:23:23 am »
Yes, but not all of the same style. IT175D/E had a lot less ribs - not sure about 175F, but I thought they were like 175D/E.
Offline JC
« Reply #13 on: February 17, 2009, 11:30:21 am »
I tho't IT175D/E forks were 34mm OD? Was I wrong?
