Clubroom
Tech Talk
online bearing catolog?
Topic: online bearing catolog? (Read 1759 times)
February 15, 2009, 12:09:42 pm »
For my bitza I'm looking at playing mix and match with hubs etc. I would like to change wheel bearings for axle and check various availabilities. Anyone know of an online bearing catalog?
maicomc490t
Re: online bearing catolog?
February 15, 2009, 02:57:44 pm »
Just did a quick google on FAG bearings - a good mainstay of QUALITY bearing and associated products and after a bit of fiddle came up with this which is a good start. NSK SKF etc would all have a similar catalogue or dogalogue depending on what you are searching for plus HEAPS of stuff to educate any of us in the finer points of bearing design and application.
http://medias.ina.de/medias/en!hp.ec/1_R
*0;aVfsehJzgMIa
I typed in - fag bearing catalogue - and took it from there and am sure most prominent brands would work the same
Dave Mac
VAPOUR (AKA HYDRA / HYDRO / AQUA / WET) BLASTING AND GENERAL ENGINEERING 0416074750 (or)
[email protected]
BULTACO M49 parts wanted
LWC82PE
Superstar
February 15, 2009, 03:01:01 pm »
if you want, tell me the OD, ID and W and i will look in the SKF book for you. i looked into the same thing also as i wanted to use a hub with 12mm axle but change bearings so they were for a 15mm axle or something like that.
Berg400
February 25, 2009, 11:29:40 pm »
Try timken bearings, from memory they have quite a comprehensive catalogue. You used to be able to download it, if not let me know I have alot of that stuff on my laptop.
Clubroom
Tech Talk
