Marketplace
Wanted
Husky 360 wr 1976 Crank Shaft Right
Topic: Husky 360 wr 1976 Crank Shaft Right (Read 1660 times)
DG87
February 11, 2009, 06:38:12 pm »
Does anyone know where I can find one of these
Crank Shaft Right 16 10 851 01
PEZBerq
Brisbane
Re: Husky 360 wr 1976 Crank Shaft Right
February 17, 2009, 10:17:33 pm »
Any good bearing supplier will be able to supply an equivalent. Do you have one to use as a sample?
Otherwise measure the crank shaft stub diameter where the bearing mounts and then measure the crankcase seal housing OD. These two dimensions are the critical ones for the supplier to match a seal for you. For seal width you should measure the housing where the seal fits in.
If you want I can measure my 240 WR seal width as a guide. Let me know. Good luck
DG87
February 17, 2009, 11:17:55 pm »
Thanks PEZberg, but I am am looking for the crank shaft itself , I re-checked in the Husky parts manual and found another part no for the 360 Part no 16 10 868-01 . I see you have 240 wr, I also have a 1983 240 wr
Marketplace
Wanted
