Author Topic: PVL Maico ignition  (Read 35267 times)
Re: PVL Maico ignition
« Reply #30 on: September 21, 2007, 04:10:51 pm »
I'm a bit confused about an earlier comment about GV plugs causing no start or using more power etc, but the B8EGV is a racing plug with the letters GV at the end and its not a resistive plug. whats the go? I use them inmy 465 with good results, they handle fouling very well.
that info is from PVL themselves regarding this application.  your application may be differant, i just got it from them.  i still use the old fat lawnmower ones in my 2 smokers and they run, it was just a cut and paste for this problem.  If a plug works in your bike stick to it.
Maico31
« Reply #31 on: September 24, 2007, 09:01:10 am »
Thanks to everyone that helped with info on the PVL ignition. It seems that i have a digital stator with an analog cdi module going by the part numbers stamped on them. I bought the PVL on Ebay from a private seller in the US who won't answer my emails, so i guess it's buyer beware when shopping on Ebay. I now need to get the correct analog stator for my 490 Maico to be able to use the ignition. Cheers
« Reply #32 on: September 24, 2007, 09:32:10 am »
you can buy the stators seperately so you can still salvage the idea.  PVL parts are sold individually as well.  relist the digital stator to fund the analogue on or vise versa
PA - prefix means its analoge, if you buy any online ask for the part number if its PA they have the analoge  (PD is digital) simple huh  ;)
ANALOG OPTIONS ($ USD)
PA900 PVL Coil for Motoplat Ignitions   $154.95
PA901A PVL Coil for PA110 / PA111 / PA132 Kart Ignitions   $125.95
PA700 PVL Coil for Analog or Digital   $80.95
PA720 PVL Dual Lead Coil   $99.95
PA800 PVL CDI Module, Analog   $50.00
PD829 PVL CDI Module, Digital   $249.95
PAST1 Stator   $149.95
PA910M Puller for Motoplat Ignition   $15.95
PA910P Puller for PVL Ignitions   $15.95
ROTORS   $129.95
MAICO - complete
PA192 125cc With Points (Thru 77)   $394.95
PA069 250cc and Up  With Points Systems (Thru 77)   $409.95
PA070 125cc/250cc  All Models (78-93)   $344.95
PA183 251cc and Up  All Models (78-93)   $494.95
« Last Edit: September 24, 2007, 12:33:06 pm by Freakshow »
« Reply #33 on: October 30, 2007, 10:13:02 pm »
probally should have looked like this one, normal PVl stators dont have that wound coil on them so, id say the maico needs  somthing a little differant to the norm if this is what it should have looked like.
http://cgi.ebay.com/ebaymotors/MAICO-1981-490-440-450-AND-250-PVL-IGNITION-NEW-NR_W0QQitemZ290175317047QQihZ019QQcategoryZ35571QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Expat
« Reply #34 on: November 28, 2007, 08:15:50 am »
Yamaboy, does your YZ465 PVL ignition use an internal rotor in place of the original outside flywheel?
Do you use PVl bolt on weights ??
I want to fit a PVL to my Husky but would like to keep the same weight as old ignition flywheel to calm its power hit.
