Author Topic: DT1 parts.  (Read 1893 times)
hotdog1975
DT1 parts.
« on: February 11, 2009, 07:54:35 am »
Contact this guy through the IT forum.
Hi,
I have a pile of spares left over from my resto, Was going to build one mint and one scrambler. Finished one, cant bear to build another without making in mint too.
Anyone interested in DT1 250 new and used stuff let me know.  Nearly enough to make 2 bikes, well sort of?  Have sold a few things already.
New Items   OEM Yamaha   2   120-15371-00      Breather, engine case
      1   122-23411-00      Race ball 1 steering
      1   122-23412-00      Race ball 2 steering
      1   122-24610-01      Fuel cap
      1   132-18113-01      Cover, change pedal
      1   156-23411-01      Race ball 2 steering
      1   156-23412-00      Race ball 1 steering
      2   156-24181-00      Damper, tank locating
      1   164-23462-00      Seal dust, steering
      2   168-23145-00      Oil seal (forks)
      2   214-13161-01      Pipe delivery (oil pump)
      2   214-13174-00      Holder, oil pipe
      1   214-13555-00      Joint, carby
      1   214-14613-00      Gasket, exhaust pipe
      4   214-14683-01      Spring, hook exhaust
      1   214-15416-00      Cover, oil pump
      2   214-15617-00      Circlip, kick lever
      1   214-15618-00      Cover, kick lever
      2   214-21615-00      Washer, special (rear fender)
      1   214-23421-02      Plate damper, steering
      1   214-23422-00      Plate damper, steering
      1   214-23423-00      Plate damper 3, steering
      1   214-23451-00      Bolt, steering fitting
      2   214-24311-00      Pipe, fuel (straight pipe only)
      1   214-24512-00      Gasket, body (petcock)
      6   214-25118-00      Special washers
      2   214-25149-01      Clutch, meter (speedo drive in front hub)
      1   214-26281-00      Cap, grip upper (throttle tube holder)
      1   214-81321-20      Contact points
      1   214-82508-20-00      Main switch ass'y, absolute mint
      2   93101-12004      Oil seal, gear shaft
      1   93101-20008      Oil seal, kick start
      1   93103-30044      Oil seal (Crank shaft)
      1   93103-42045      Oil seal (Crank shaft)
   Restored
      2   214-24710-00      Seat ass'y (powder coated base, foam restored, repro cover fitted)
   Non Genuine
      1   214-21787-00      Emblem, enduro (reproduction, perfect)
      1   214-11631-00      Piston STD (made in Japan, NOT OEM)
      1   214-11601-02      Rings STD
      1   214-11633-00      Piston pin
      2   604-11634-00      Clip, piston pin
   Used
      1   Frame, freshly powder coated black 1969 model
      1   Frame, ready for restoring 1969 model
      1   Swing arm, square tube.  Freshly powder coated         SOLD
      1   Swing arm, square tube. Ready for restoring         SOLD
      2   Sets of front forks, need restoring. Including triple clamps            each
      1   Front fender, needs restoring.  No mounting hardware
      1   Fuel tank, blasted and primed only,
      1   Oil tank, needs blasting
      1   Head light bucket with ears, needs blasting
      1   Complete bottom end, not sure of condition
      1   Enough parts to build a complete bottom end (all in bits)
      1   Engine barrels, one with new sleeve fitted, both STD bore
      2   Cylinder heads
      2   Ignition coils
      1   VM 30 carby,
      1   Rectifier   168-84721-60-00
      1   Tail light lens
      1   After market exhaust pipe         SOLD
      1   Handle bars, nice and straight, have been sprayed black
      1   Front stop switch ass'y 233-83980-30
      1   Front wheel without tyre, 19"
      1   Front wheel with original tyre fitted, 19"
      2   Front wheel brake ass'y
      1   Front hub only, centre powder coated Precious Pearl Silver ready to lace
      1   Rear hub only, centre powder coated Precious Pearl Silver ready tolace
      1   Rear wheel with knobby fitted, has buckle in rim
      2   Rear sprockets
      2   Rear wheel cush drives
      1   High beam pilot light, excellent condition
      1   Pair racing shocks
         All other bits including brackets, foot pegs, axles, etc etc
Andrew
