Author Topic: Patchwork Montesa  (Read 4851 times)
Offline Tahitian_Red
  • Mugen ME480
Patchwork Montesa
« on: September 18, 2007, 09:25:53 am »
I'm trying to piece together a '74 Montesa VR.  Are there bits from the V75 and VA that will work on the VR?  Thanks!
The "Factory Novice"
California, USA
Re: Patchwork Montesa
« Reply #1 on: September 18, 2007, 10:25:29 am »
I'm 98% certain wheels (brakes etc) and all engine bits swap. VA cases are the same but VB onward differ. I'm 90% certain the tank swap although there are small differences like breather position etc. VR are also slightly smaller than VA or VB.
I don't know if improvements were made with porting or compression etc for performance increase over the models.
Check to confirm all the above.
I have an original bore 360 barrel and head that will go straight in there if you are interested  ::) :P ;D
« Reply #2 on: September 18, 2007, 11:10:34 pm »
Here you go Red,
http://autos.groups.yahoo.com/group/MontesaGroup/?yguid=302718682
Follow the links and you might find out more.
A piccy of the VA....
the V75...
and again....
the VR....
and the VR again...
The first VR has a slightly different tank with the mounts on the side rather than the top.
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #3 on: September 19, 2007, 06:39:33 pm »
V75 had very slight porting changes to let the engine hit peak power lower in the rpm range.  VA 250 eliminated the exhaust bridge, with a large oval shaped exhaust.
Everything else will interchange between the three models.
  • Mugen ME480
« Reply #4 on: October 16, 2007, 02:33:43 am »
Well, I have the front end from triple-clamps through front wheel assembly, motor, rear wheel assembly, tank, seat and misc. bolts (axles, pivot, motor mounts).  I have a line on a frame, but not sure if that will pan out.
Any problem areas I should look for on a used (73-74) frame?
California, USA
