Clubroom
Tech Talk
cr480 wont start
Pages:
All
Topic: cr480 wont start (Read 7783 times)
Hoony
Melbourne, Vic.
Re: cr480 wont start
Reply #15 on:
February 08, 2009, 08:23:47 am »
if all else fails it could be an intermittant cdi fault. i had a similar problem. is the spark VERY strong?
Long time Honda Fan, but all bike nut in general, Big Bore 2 stroke fan.
http://www.youtube.com/watch?v=XJoKP6MawYI
Snowy 76
Reply #16 on:
February 08, 2009, 10:22:14 am »
Sure it`s not just Flooded ?, had similar just recently on my 480, Plug Didn`t look wet, Pulled out plug, 3rd gear, gave her a push for a 100 mtrs or so {once all weezing and coughing had ceased} plug back in 2nd kick way she went. Just a thought.
Couple of CR`s
caps 999
Reply #17 on:
February 08, 2009, 10:45:05 am »
i have a small feeling it may be the plug cap as the fit looks kinda lose but there is a string spark when i remove the plug and hold the cap
MUGEN power
jimg1au
Reply #18 on:
February 08, 2009, 12:38:38 pm »
dont muck about looking at this and that.give a good dose of gas or areo start down the plug hole put new or working plug back in.it will start if there is no ignition problems.i use ths method on boats for years.i have a 70hp yamaha,i bidnt use it for 18months due to injury.charge up battery and wind over.no fire i had spark no fuel.speezed fuel bulb again cranked over nothing.took 1 plug out sprayed areostart into cyl.replaced plug.fired up first turn of key.problem now fuel del at cold.electronic enrichener $300.00 is at fault.also check that the motor is not full of fuel i am asumeing you carb needle and seat is in good condition and you didnt leave fuel tap on and crankcase is not full of fuel.i bought a 1979 it400f once of a guy said it was running last month.the obove needle and seat combined with leaking fuel tap was all that was wrong with the bike.
have fun try 1 thing at a time and document your efforts so you can see whats happening
oldyzman
250 two stroke!
Reply #19 on:
February 08, 2009, 03:58:48 pm »
Good point snowy76, I had an old mx which would not go with a new plug, i adj timing played with fuel and even tested the coil. the fault was a bad new plug- put the old one back in and it went ok
pancho
Reply #20 on:
February 08, 2009, 04:12:04 pm »
i bet it was an ngk
caps 999
Reply #21 on:
February 08, 2009, 05:17:37 pm »
problem solved turns out the bike was well past floded i pulled the head off got the piston to the bottom of the stroke and tiped the bike i got around a litre of fuel out the bottom end i res assembled and it strated first kick i dont know how that much fuel got in the bottom end but it rides like a weapon now
spent the arvo at parwan and had a ball
MUGEN power
oldyzman
250 two stroke!
Reply #22 on:
February 08, 2009, 09:53:17 pm »
Hey wally it was ngk.... Glad to hear you got it started, my brothers old it175 did that when we were kids and he thought it was seized as the crankcase was full of petrol- needless to say he always tuned of the fuel when stopped from that point on
Pages:
All
Clubroom
Tech Talk
cr480 wont start
