Author Topic: KX want start  (Read 7303 times)
Hornet
KX want start
« on: February 05, 2009, 09:22:15 am »
I wanted to go for a blast coming weekend with the boys , but my  KX want start . It ran nice till now .
I washed and polished it , thats all . The bloke across the road , a tree surgeon that plays with chainsaws all the time ,came last night to have look .
Its got fuel , it has spark . He even tried to push start it . All we got out of it , was a bang. Thats all , what could it be ?
Offline shortshifter
  • Sunshine Coast QLD
Re: KX want start
« Reply #1 on: February 05, 2009, 09:37:56 am »
Sometimes my little kx125 is like that and it goes after I disconnect the fuel line and let it run a bit then reconnect it to the carbi so it must be a bit of an airlock on mine.
360DUDE
Re: KX want start
« Reply #2 on: February 05, 2009, 11:30:40 am »
You said you washed it, any chance you got water in behind the stator cover or in the other electics??
if so undo the stator cover and give it a good spray with wd40 or crc.. and try to push or roll start down a hill
Years ago i had an RM125 rode it and put it in the shed, the next day i got it out and it wouldn't go.
It had fuel and could see some spark from the plug, all it would do is pop every now and then trying to push start it....
Turned out the stator coil needed to be rewound
Good luck
Luke 8)
Hornet
Re: KX want start
« Reply #3 on: February 05, 2009, 07:10:01 pm »
Just come in ,sweating from kicking and pushing . Tried the fuel line and used the stuff  that my treelopper mate   gave me ( CR something) . All it does , it shoots and backfires. >:( >:(
Offline Marc.com
Re: KX want start
« Reply #4 on: February 05, 2009, 07:37:51 pm »
water in the fuel, water in the carb, water in the air filter, i know it is stating the obvious but did you drain carb bowl, fuel etc.
360DUDE
Re: KX want start
« Reply #5 on: February 05, 2009, 08:06:20 pm »
if the fuel is ok, change the spark plug and make sure the lead is in the spark plug cap properly..
 this is going to be a process of elimination  ;)
Hornet
Re: KX want start
« Reply #6 on: February 05, 2009, 08:11:01 pm »
There is plenty of spark  ;D  I held the plug when my friend kicked ..........
360DUDE
Re: KX want start
« Reply #7 on: February 05, 2009, 08:14:45 pm »
If you got another plug, just try it to rule it out.
Sometimes a fouled plug will spark when you crank the motor but isn't strong enough to run the motor.
Offline paul
Re: KX want start
« Reply #8 on: February 05, 2009, 08:34:57 pm »
that the trouble you used a tree surgeon ,you should off used a mechanic
mr /mrs hornet  how long ago did you have it running or did you just buy it off ebay
« Last Edit: February 05, 2009, 08:39:09 pm by paul »
Hornet
Re: KX want start
« Reply #9 on: February 05, 2009, 08:51:34 pm »
Only went for a ride the other day  and my friend just lives across the road  and plays and tunes his chainsaws and whatever other noisy things hi has , all the time.
Offline frostype400
Re: KX want start
« Reply #10 on: February 05, 2009, 08:58:52 pm »
whats it go like if you put some fuel done the plug hole should fire for a second maybe water in the carbie or no fuel?
1971 tm400 and PE's
Re: KX want start
« Reply #11 on: February 05, 2009, 09:56:30 pm »
how old is the fuel and what fuel are you using? premium or high octance fuel will go stale in float bowl fairly quickly and can make starting impossible unless you drain it.
Offline oldyzman
  • 250 two stroke!
Re: KX want start
« Reply #12 on: February 05, 2009, 10:04:48 pm »
Maybe pull out the plug, give it a lot of kicks this should clear any moisture from the crankcase, then throw a capfull into the bore, put in the plug and kick it like virgin silky terrior being forked by a great dane. Has this bike got good compression?
Good luck
Offline oldyzman
  • 250 two stroke!
Re: KX want start
« Reply #13 on: February 05, 2009, 10:06:17 pm »
R u serious fish and chips - i dont supose you weded on the kick starter too.. Just kidding
Offline oldyzman
  • 250 two stroke!
Re: KX want start
« Reply #14 on: February 05, 2009, 10:21:06 pm »
Yes mate u better get a real big welder so you can use the 5.0mm rods, those suckers are as thick as your little finger. great for gear levers also
