Author Topic: 73MXA Cylinder Nut - Which Socket?  (Read 7661 times)
Offline BJJ
    • Remote PC
« on: February 03, 2009, 05:12:05 pm »
What type of long socket do you need to use for '73 MXA Cylinder nut?
I know it needs to be long,  but what size is it?
Will have to buy one from a tool shop  :-\
Thanks in advance
Re: 73MXA Cylinder Nut - Which Socket?
« Reply #1 on: February 03, 2009, 06:09:16 pm »
it 13mm you can use 1/4 drive sockets i have one if you get stuck but i bought mine from auto parts at meani
not sca
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #2 on: February 03, 2009, 06:41:24 pm »
not sca
Are you sure? my barrel nuts were 14mm, but the cylinder head nuts were 13mm
Ban BLACK rims NOW
Offline BJJ
    • Remote PC
« Reply #3 on: February 03, 2009, 06:47:38 pm »
It's the ones that hold the barell down onto the crankase.  Down that deep hole.  The sockets and extensions I have tried so far (mix of both size drives)  don't seem to want to make their way down the whole.
Offline BJJ
    • Remote PC
« Reply #4 on: February 03, 2009, 07:15:08 pm »
Hi Paul,  I guess I better say this is a Yamaha MX,  not a Montesa/Maico (although that Allen Head example looks like it could be universal).  The heads of the nuts are hex,  like this one:
http://cid-0970e1979402bd5b.skydrive.live.com/browse.aspx/MXA?authkey=2hZNJNNBJW4%24&ct=photos
« Reply #5 on: February 03, 2009, 08:17:34 pm »
i will check tomorrow as i am at work now
jim
Offline JC
« Reply #7 on: February 04, 2009, 09:38:40 am »
If they're the same at the DT (& I'd think they are) they're 13mm, but you MUST use 1/4" drive sockets - my 3/8" drive ones are simply too big OD to fit down there.
« Last Edit: February 04, 2009, 01:03:22 pm by JC »
« Reply #8 on: February 04, 2009, 10:13:22 am »
can you crack them through the side ? and then use whatever you have to spin em around  ?
actually forget that use the right socket :O0
Offline BJJ
    • Remote PC
« Reply #9 on: February 04, 2009, 10:44:49 am »
Thanks JC  (and freakshow for imagination).  will give this a go.  Will report back next days to the thread how I get on.  Regards,
« Reply #10 on: February 04, 2009, 12:09:50 pm »
My 3/8" drive AWB/SuperWorks Gold socket set fits down the holes.
Been a damn good set of tools, despite the SuperCheap stigma - only ever broken one bit, which was the 14mm socket while undoing a Volvo head bolt, using a 5.5' length of pipe for extra leverage...
Offline JC
« Reply #11 on: February 04, 2009, 12:58:07 pm »
Billjack,
the heads of the nuts round off fairly easily. (Unfortunately I speak from experience) Then you have a problem I haven't yet overcome.
Make sure yr socket is a good fit & don't force it if they're not moving. Maybe good idea to spray w Bolt-off or the like a while before you try
« Reply #12 on: February 04, 2009, 12:59:22 pm »
Volvo's have worse stigma than Super Cheap so don't let that worry you :-* But those SWG tools are VERY good.
Offline BJJ
    • Remote PC
« Reply #13 on: February 04, 2009, 02:00:22 pm »
Thanks guys,  I am very impressed with the help I have got from this forum.  Considering all the other bikes will be gone within the week  (eBay).  Then I see no other bike project for me to be dissalusioned with (is that a word).
Maybe that 600 thumper   LOL.
I'll get to a tool shop in the next days and report back.  Once again,  thanks.
Any small information I know,  in these situations is invaluable.
« Reply #14 on: February 04, 2009, 03:49:35 pm »
No probs im good with imagination.
P.S the 73 is just the MX the 74 speedblocker is the MXA
