Author Topic: PE 250 Z no spark  (Read 3967 times)
Offline rocketfrog
PE 250 Z no spark
« on: January 31, 2009, 07:36:54 pm »
PE GURUS, I have started to troubleshoot a no spark issue, so far I have changed plug and coil with known serviceable components, disconnected kill switch to eliminate stray earth and am down to either the magneto or the CDI Unit. Does any-one have specifications for the winding resistance and a method to test the CDI?  I am not familiar with the PE range and  have not any publications on the type. From experience it usually does no good to grab a spare CDI from the wrecker unless you can verify the condition of the item first, but if any-one specialises in post 80 PE's and can spare a CDI for troubleshooting I would appreciate a loan if the magneto tests OK.
Re: PE 250 Z no spark
« Reply #1 on: January 31, 2009, 07:42:36 pm »
do you have a 82 250 Z aswell? they are comming out of the wood work. that could be 3 now.
all info can be found here
http://groups.yahoo.com/group/PEmotorcycles/
and
http://pureenduro.free.fr/
this is the 82 manual here
 http://pureenduro.free.fr/Div/documentation/PE%20250/manuel%20suzuki%20pe%20250%20Z.pdf
i am looking at a copy in my hand right now and there is CDI specs and stator tests
there are manuals there with CDI and stator tests
« Last Edit: January 31, 2009, 07:44:12 pm by LWC3077 »
