Author Topic: OIL MIX FOR A 125 ABC ????  (Read 3141 times)
Offline RM Ted
« on: January 22, 2009, 01:24:58 pm »
OK ALL YOU RM 125 C OWNERS. IM INTERESTED TO KNOW WHAT OIL AND WHAT MIX YOU ARE RUNNING IN YOUR RMS. THE BOOK TELLS TO RUN A 20 TO 1 MIX. THE BIKES ARE RUNNING ON THIS MIX WITH PREMIUM BUT THEY ARE A LITTLE ROUGH. IM THINKING MAYBE THE OIL IM USING AND MIX SHOULD BE A LITTLE DIFFERENT ???
« Last Edit: January 22, 2009, 06:17:58 pm by CLARKEY »
1978 rm 125 x 3
1981 rm 125
1987 rm 125
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: OIL MIX FOR A 125 C ????
« Reply #1 on: January 22, 2009, 05:06:11 pm »
on the PE list, we have found that most of the guys are best between 20:1 and 32:1 - higher and things tend to wear and fizzle...
If you tootle around try 30. If you go 10/10ths, 20 seems to produce the most power. That's what our consensus seems to be.
Hope it helps.
« Reply #2 on: January 22, 2009, 05:09:27 pm »
Offline RM Ted
« Reply #3 on: January 22, 2009, 06:17:23 pm »
THANKS LWC3077, I HAVE BEEN LOOKING AT THIS TOPIC??? JUST WANTING TO KNOW WHAT OTHER ABC 125 OWNERS WERE USING, OILS ETC AND MAYBE IRON OUT SOME BUGS.
« Last Edit: January 22, 2009, 06:20:47 pm by CLARKEY »
1978 rm 125 x 3
1981 rm 125
1987 rm 125
Offline oldyzman
  • 250 two stroke!
Re: OIL MIX FOR A 125 ABC ????
« Reply #4 on: February 02, 2009, 10:03:44 pm »
Ive been using 30:1 semi syn motorex with no worries in my old girls from 69ts/tm250 to a yz125e, but i will now try 25:1 since what i have read lately on the subject.
