Author Topic: Wanted, fuel cap for TS125/185/250 GS250/400/450/550/750  (Read 2337 times)
Doc
« on: January 21, 2009, 01:04:43 pm »
Looking for a push in bayonet type locking fuel cap for a TS250C tank. This is the type that needs a key to open and shared with many models from the 80's GS series of streetbikes or '78ish TS125/185/250's. Some GN models also used them and no doubt others too. The hole size in the tank is approx 43mm so the slip in bayonet piece would be about this dimension or a little less. Picture below gives a bit of an idea of the item required. Thanks in advance.
Re: Wanted, fuel cap for TS125/185/250 GS250/400/450/550/750
« Reply #1 on: January 21, 2009, 01:14:09 pm »
YEs there is one on that  TS250 i told you about, buy the cap throw in bike for free :O)
« Reply #3 on: January 21, 2009, 05:20:05 pm »
fUC ILL SELL YOU THE WHOLE BIKE FOT THAT , AND YES IM MEAN IN POUNDS :o0
Doc
« Reply #4 on: January 21, 2009, 06:24:55 pm »
 :D Thanks CG, that's the ones alright but for $100 I can go and buy one from Suzuki ;) I was hoping for a John West reject and maybe be lucky enough to get a key also. Ironically I had a whole GSX250 offered to me a while back with exactly the setup I need and I rejected it :o you can usually bet if I reject something I think it's pretty much worthless but I should have at least grabbed the fuel cap and keys..they were perfect! :'( ya get that :D anyway if one spots a cap for negligable $ then I'm shirly interested, if it's got a key I may even go double figures :P ;D
Freaky, I have this wee logistical problem I need to address before the TS can grace my space but I maybe onto a reasonable solution..I hope :P does the TS happen to have keys cause that'd really sweeten the deal! ;D I must be insane ::)
« Reply #5 on: January 21, 2009, 11:14:32 pm »
last i looked it did, unless it fell out and its in the garden but i can go mowing and see if it shoots out.  Havent heard from you mate bout the TM , but when he comes down he can collect this for you as well.
« Reply #6 on: January 21, 2009, 11:20:10 pm »
try searching UK ebay for TS suzuki. theres over 30 pages to sift through! even if its got no key there would be a 3 digit number on it and i think a lock smith can make a new key. also you can get nos suzuki keys on ebay sometimes. one time a seller had some and you just had to tell him the key number you needed.
« Last Edit: January 21, 2009, 11:23:17 pm by LWC3077 »
