Author Topic: Flat track frames  (Read 36611 times)
Offline Mick22
Flat track frames
« on: January 19, 2009, 03:41:45 pm »
Why do USA style Flat track bikes always use after market frames ? Is just for weight or is it about the geometry ? The only real difference I can see is that they have a steeper head angle is that correct ?
I'm building a flat tracker at the moment and want to try and get the geometry close so if anyone can offer any frame advise it would be much appreciated :)
Re: Flat track frames
« Reply #1 on: January 19, 2009, 04:55:18 pm »
Not all US bikes used A/M, most early stuff was just modifed or in the case of the astro came out like that, but having said that Most Aftermarket frames were Chromoly so they were lighter and stronger.
Angles where only changed to make smaller circles, or built more upright for TT and jumps most geometry never strayed far, it was the forks and arse end that took up a lot of setting up.   Many frames where just modified Standards like nortons and triumph it wasnt till the late 60's the after market frames really took off. Over time the guys who played with frames rather than having to go through the exercise of cutting lugs and bits off and welding bits in for strenghten just found it easier to just start from scratch, plus they where able to make it  how they wanted and so much lighter with the 6series tube and 4130Cro-mo, as usual as these guys started winning more and more so the next guy would ask for a set of lowered pegs, or can you build me a frame too and on it went until you have 5-6 guys all building and selling frames.  IF you  draw a line through the swing arm in the picture below you can see the the whole chassis is lower and streched even through it is compact, the centre of gravity is the focus, as is in the bottom half and rear of the frame not the head angles, just changing the head angle will not give you all of those peices of the puzzle you really need.  if you look at it compared to my MX 360 in the back ground (even though the fork are turned in ) there isnt a lot off differance in the head angles, there really not that far apart .
i think my tracky Rakes around 25 to 26 degrees but then variable a degree for every inch you move the forks upwards and Low trail numbers of between 3 to 4 inches making the bike easy to point into turns, wheel base is  54-57 inches, but having said that it is as light as shit and would be half the weight of a normal bike.  So all those combo's make the frame fast, not just a head angle.
IF you look at the more commercial frames that were sold into shops and well promoted  like a champion, if you speak to people like Neil keen he will tell you " champions were almost copies of the Yamaha dt1 frames, just "cleaned up a bit. Doug schwerma, in the beginning , knew nothing about geometry and freely admitted it,  but was a brilliant promoter of his product.   Neil says the champions handle bad, ( he sold them as well,) and if you knew how to ride a tri. or bsa or a trackmaster they were poor, but we've all seen guys who didn't, win a lot of races with champion. " they were just well promoted and sold over the counter, rider feedback came afterwards, where as other frames you took them your motor and told them how you wanted it to run in or out.
Ray and neils originally geometry was based on the truimph, they were making trackmasters for Racing themselves and sold others off paying for there racing, neil made his first infamous DT1 Frames for the new unstamped ( pre production) Yamaha motors for the Japs out of old truimph bends spliced together,  (see pic of my first batch DT1 frame its got way too much headroom) and yet the set up worked still because of how he positioned the motor and how low it was also the swing arm is critical.   Others like Boss custom built them for racers and himself, and by the time Terry knight left Doug to set up his business after they closed under a cloud, Aftermarket frames had really become the standard and the geometry had been well founded and they were just tweeked from there.  Redline frame geometry was fairly standard too, until they sold up in the early 70's and Mike took the name only and went straight to Japan to build BMX frames.
What frames do you have now ??
Bultaco and similar units always worked very well as  really do most standard frames, the only standard frames i have heard that needed to go to the effort of raking is the TT.   But IF you stuff around with a frame angle you wanna know what your doing as it will throw everything else out, so if you mess with the front, you change the rear and there is only so far you can push the rear wheel forward so then you have to increase the heights and on it goes.
I wouldnt waste you time changing anything, the other problem you have is unless you ride the same track forever what you do on a short track wont work on a long track as well, also short trackers were only meant to go one way like a speedway bike so were kinda talking about 2 differant frame set ups anyway.
i think you would be better off changing angles if needed through taking the forks through the triples (adding degress) and looking at the swing arm and where the wheel base can be altered.  you can also make changes in the shocker body hieght ie drop to 12.5 " shocks and you totally change all the angle again.  IF you look closely at the trackmaster below notice where the motr sits in relation to the swing arm, it looks a lot lower and the swing arm is straight not going up, you would have to recreate all those angle not just the head area, down low is where its all happening on these frames, and it would be very hard to recreate that.
IF i have ever learned one thing told to me, it was that Everything you do changes somthing else, if you cant get the back out the problems at the other end ( the fronts not turning in) dont mess at where you think the problem is, as its usually caused by somthing on the other end.  Try that with kids what ever they say its doing change the opposite, because thats where the problem starts, somone once talked about cause and effect its very true.
How does all this relate to US frames, well what im saying is you probally have all you need right here already to build a great Australian dirt tracker, however if you want a good looking bike and like the look of them then styling wise you cant go past the Flat track frames, all the other stuff is just that.   Are you talking about pre 77 stuff,  after that the factorys started gettting it right and you find most frames where standard, even now most FT's are standard YZ, RMZ frames with the shocks dumped and that swing arm geometry area worked on.
Having said that if you looking to build up a v twin or other big bore from a road based unit like a harley, RS , tz etc then you should look into buying in a track frame as you would benefit from the ready made knowledge thats already set up in the frame like a missle or c&J, it would be too much effort otherwise as you would also need to mess about with the seat positions, rakes, pivots points etc. you would really need to know what you where doing otherwise you would have a very expensive deco lamp holder in $$$ cromo.
What have you got and what are you looking to build ?  that is probally the question i should have asked rather then wasting all your time reading this .   sorry. :)
« Last Edit: January 20, 2009, 02:14:32 pm by Freakshow »
Offline Mick22
« Reply #2 on: January 19, 2009, 05:47:48 pm »
Thats for the reply Freaky,
Looking at building USA style flat track bike, using a Honda CB450 road bike as a base. They raced them in the states in late 60's early seventies (same sort of look as the XS650 machines) but I mainly chose the CB450 because I've a shed full of them, one is a road race bike with lots of good bits so it will make an easy conversion. I'm mainly building it so it looks right for meetings like Broadford Bonanza to go out and do a few laps and scare the shit out of myself... small 19 inch fronts just don't work at broadford :). I'm also half way thru doing a TT500 (with a raked frame) but thats going to be OZ style 21 inch front etc thats hopefully going to be more of a competitive race bike.
I've been studying photos on the internet and trying to work out why so many of the US bikes changed their frames when the Geo doesn't look any different but from what yor saying it was more about weight and bling (is there a 70's word for bling ;D) than it was about the geometry
« Last Edit: January 19, 2009, 05:53:03 pm by Mick22 »
Offline jimson
  • Sanctuary point N.S.W
« Reply #3 on: January 19, 2009, 06:42:41 pm »
Freaky can you race that bike in Aussie the way its set up no front brakes and rear disc looks cool  8) jimson
« Reply #4 on: January 19, 2009, 07:28:18 pm »
Mick im saying there was geometry but more so less weight and lower centre of gravities.  what i was trying to say is changing the head angle wont be any kind of panacea ( although on the TT - i here its a good thing to do)
The early bikes ran solo and pillion seats so the bling only came later when they where able to put more adverticing space over the glass.  8)
Yes Jimson they are all raced,  the frames are good to pre 70, but brakes if used other than drum are only good for pre 75.
Our speedway bikes dont run brakes and originally neither did these so from a safety point they are safe.
Brakes came optional for AMA after 71 and air heart rear disks appeared in 1972 and fronts for TT after that, so you can run Disks no probs pre 75 but truth be know they are prity crappy and a good drum would out brake it every time. they are used really only to drag and wash off speed, rather than stab, stop and turns like mX can need.
i only run them cause thats how they work with the Quick change rears and as in speedway style you can swap the rear wheel around, (clip hubs) so you can use both sides of the tyre at one meet and besides thats how they look best and im trying to run it as it was designed.
You cant take the brakes off and stick them on something else and say its period, beside the fac they are crap they didnt appear on MX till much much later.
they are very simple bikes and very functional, if you look closely every thing has a purpose or is very cleverly designed, besides the fact they so so dam horny or PHAt as the youg fella say to me at meets.  the  maroon bike should have a solo and pillion on it but i am yet to find a good bates seats for it and i have neil on the hunt for the correct teardrop tank.  meanwhile this bike still looks good but the solo combo will look much better, should look like this pic my other Flat tracks ill keep the glass on them as thats there period and they look the shizzle in it  :D
« Last Edit: January 19, 2009, 07:35:32 pm by Freakshow »
« Reply #5 on: January 19, 2009, 07:37:18 pm »
although im still partial to the new FT exotic looks
« Last Edit: January 19, 2009, 07:38:54 pm by Freakshow »
Offline jimson
« Reply #6 on: January 19, 2009, 08:32:01 pm »
The old one's got more soul Freaky  8) jimson
« Reply #7 on: January 19, 2009, 09:03:48 pm »
true.  if it could speak it would have some great stories to tell.
Talking about frame set ups and tracks, below is an indoor meeting on concrete and it goes in a tight round circle.
Now i think to my self what a Fken waste of time, but there was and still are indoor meets on concrete... please explain.
but thats the yanks for you huh.   Any how that give you scope for how our tracks dont really relate to these and how youll be struggling to get the same perforamnce out of a short track frame set out for a completely differant purpose and frame feedback/geometry  ???
« Last Edit: January 20, 2009, 04:05:30 pm by Freakshow »
Offline Mick22
« Reply #8 on: January 20, 2009, 10:53:30 am »
Hey Freaky, what about wheel sizes for a pre 70 bike. I love the look of 3.5X19's but i'm sure they would have had something smaller back in the day, do you know what size they were ? somewhere around 2.15X19 I'm guessing ? I'm going to Run 18 X2.15 with michelin trials tyres because thats what I've got but just wondered what the right size should be for that period... If I find the time I might build another set of wheels
« Reply #9 on: January 20, 2009, 11:32:28 am »
This might shock a few people but I agree with Freaky on his summation on flat track frames. The early two stroke aftermarket frames by Doug Schwerma (Champion) do indeed have very similar geometry to early Yamahas. The first Bultaco Astro frames were merely Pursang frames with all of the gizmo brackets removed and a tighter steering head, achieved with different triple clamps rather than frame surgery.
In my opinion and in that of many of the folks who've tried American aftermarket short track and flat track frames on our short circuit tracks...they just plain don't work. I think it's down to the different track surfaces and varying shapes of our corners. There may be more, technically smarter reasons but whatever they are, I've only ever seen a small number of riders come to grips with them. Chris Kelly and Gary Chasemore were killers on Astros in the 70's and the great Peter Goddard kicked some arse on a very trick Mugen (or Yoshi, I can't remember) XR500 powered C&J. Nearly all of the others have failed for various reasons.
In my case, I can identify one problem that came to light on both of my Champions. My first one, fitted with a methanol SC500 Yamaha engine used to get a real wobble up coming out of fast corners. I tried stiffer spring rates, stiffer forks, longer and shorter shocks, and Carlilse, Michelin, Dunlop and even a Pirelli Phantom road tyre with some serious knife work on the pattern. Nothing worked. It was still a bucking bronco coming out of fast corners in a high gear. Then one day a mate offered to follow me around and observe what was happening. It only took 3 or 4 laps for him to see that the swingarm was flexing like buggery under acceleration. That was on the bitumen like oiled surface at Nepean, a surface those bikes were never designed for. I sold the bike to Edgar Phipps and he braced the swingarm quite substantially and today the bike seems to behave itself a lot better. Even though my XL350 Champion was used for motocross, it still showed a lot of swingarm flex. I braced the arm with 1"x1/8 stainless flatbar and built up around the axle slot area and eventually that problem went away. It didn't improve the overall ridability of the bike however, I hated it in fact, and I sold it to Mick Murnane in Victoria. I believe it's for sale again by it's current owner.
This is my Champion Honda in MX trim. It was as pretty as Britney Spears but handled like a bucket of shit.
This is an example of the locally made Redline replicas being made in the Newcastle area. This particular one is Alan Joneses 850 Nourish Weslake version.
« Reply #10 on: January 20, 2009, 01:49:06 pm »
What era ?  each would be differant.
pre 70 any road size you could find mostly F/R spoolers 18, 19 in Wm 2-3
pre 75 Borrani or akront Wm 3+ sizes to take 4 inch - any thing that holds a MT Perelli, carlise, goodyear, mostly taller trial type  patterns
Post 75 prity same sizes to suit goodyear and maxxis style treads which they still use today except in the side choclate block patterns exclusively
Also this would depend alot on district and track, for example if you raced at salinas is soft scrapes almost sandy, you would need to run the tall thin tyres otherwise youd be sloshing around in the soft tops.  Ascot was loaming in 75 so same there taller tyres would stear better and not run on, but on Hard clay based tracks like Lodi youd want to run wide flat tyre like the carlise cuase it was almost like bitumen.   There is no right or wrong for that period, least of all who is going to tell you otherwise ? Shouldered, unshouldered its all good.
IF you remember as JIm would say guys where building bikes in there sheds after there day jobs they would use whatever they could, to get on the track, so if you could buy it or get it from salvage it would be period correct and historically correct.
Running a US frame wont win you an Aussie title but id have to agree ( more oxygen for Ross please ) as Firko says " one sexy britney spears" .
Most short track frames ( as discussed here) are more akin to a speedway constant radius track, until you find tracks evolve to that kind of layout you wont find F/T short track frame up there in the points.  I have been asked to take my good bike out for a lap during a speedway round next year so we might even be able to push to get a class up and running if i can get 3 more bikes on the line, they would be better suited to those kind of tracks not the soft surface kidney shaped, sweepers and off camber tracks we generally ride here.
Depending on the size and tightness of the track you couldnt go past many frames already out there like TM, XL and many bultacos but again it really is track and surface specific.  You could almost do what i have done, have bikes you love. built them to look shit hot, but race shit, and then built a second batch that look shit but ride shit hot.  i dont think there is a middle point if you intend to use a short track frame.
i ride and collect mine cause they just look horny, i think they are a bit like a muscle cars, not much practical use here in Au, but a dam fine ride and will get ya laid :O)
okay maybe i exagerated there, but you get what im saying they have the "look" even when standing still, and the beauty is you can customise them any way you like unlike a MX resto that needs cirtain plastic and certain NOS bits, the elements that make the Ft correct are very simple and very special, other than that you could build any combinations of frame and motor to suit your individual taste and thats the other thing to appeal to me.
Pic below is one of my DT1 champions, look at the frame compared to firko MXers, prity much the same and very Dt even the square swing arm ( most early flat trackers used the tube swinger so that also point you to where he got  his geometry from.)  Now Look how the swing arm position end up on the MX, some how you can see that area is wrong in relation to the countershaft and where the motor sits and then the way the arm runs out on a very step angle, its just inst going to make a good MX frame it would be a pain in the arse as the front is to low for the angle its carrying and would be like herding cats ( shaky on the bars) the back end would have been pushing more on itselfs with load going back into the swing arm not the shock, not to mention the frame spine is low and angled with the seat just kinda plonked high on top.  But GMC or PEte Hoey would be able to explain all that. i think moving the lower shock mount forward would help, but then again as above ever 20mm changed somewhere can make a 50 mm change felt elsewhere, some things like time space continuams just cant be messed with and only in small way unless you want bad things to happen.
 And im glad you agree firko, Champions where just well marketed and not really that great a frame.
As this forum also mentions there are better scramble, MX frames you can find than the US stuff, id say any A/m british frame would beat it hands down in the handling deparment in a scamble style.  Although the US had some great A/M parts ( The US market was very specific so you would be picking and choosing what worked and the combinations if you were looking to go down that track)
I think US Flat trackers will grow stronger in Au in a similar way we saw Mustangs, firebirds and cameros take off and get there own following.  i think its an exciting time for these bikes right now and the future.
« Last Edit: January 20, 2009, 02:21:56 pm by Freakshow »
« Reply #11 on: January 20, 2009, 02:15:34 pm »
Your Champ is almost identical to my old SC500 version. I had a Barnes spool hub on it when I bought it but I like to stop at the end of thew start straight at Nepean so I fitted a YZ hub/19" rim combo.
« Reply #12 on: January 20, 2009, 02:29:23 pm »
Kewl.   i thinking of putting my sc500 into an MX250a/b champion frame i got and yep would definatley look at putting some brakes back and front.
PRoblem is last time i started the SC it sounded sick and knocky down below, so if i was to use it im sure it would need someone to go through the bottom end, cause if it went bang it would be costly.
although PRobally not a great combination, would be the closest i could get to building the YZ500 special, and it would certainly dig trenches.    BE very interested to see one on meth, what carb was you running ? do you take the jets out and just use the float bowl to meter the juice ...   :o
« Last Edit: January 20, 2009, 02:32:13 pm by Freakshow »
« Reply #13 on: January 20, 2009, 02:58:58 pm »
Actually having said all that , what i think would make a good pre 75 ride would be a XL350 bored out to an inch of its life sat in a trackmaster frame, i think you could get a prity good set up out of that kind of combo out there, where's pete lee when you need him he'd be able to give a thumbs up or down on that one.
MAybe where being a bit harsh really , in hindsight a good motor choice in a good frame choice and someone who knew how to ride, could infact be an aussie champ on a short tracker on the right track.  where is the DT in 2010 ?
Project id like to get onto is a Yamaha twin, reckon they would be great to ride, sounds awesome on the pipe, and spares should be fairly easy  :)
« Last Edit: January 20, 2009, 03:57:29 pm by Freakshow »
Offline Mick22
« Reply #14 on: January 20, 2009, 03:30:12 pm »
Yeah thanks for the info Freaky, The 450 is never going to be competitive even if there was a class but I'm just trying to build it as a Pre 70 bike so just trying to get the look half right :)
Just wanted a new project to have for the Broadford Bonanza as I heard they were running a US flat track session. I raced DT for years at Broadford and apart from an Astro and an XR I've never seen any other US DT bikes around.... good to see a few coming out of the wood work. Hopefully they can get a full start line of them at Broadford, I've got a mate with a genuine Harley factory XR that hopefully will come along as well!
Its a shame they got rid of the long track at Broadford would have been great to see them running around the big track.
Firko, haven't heard Chris Kelly's name for a while, he used to drop into my old work. I've heard stories of how he used to be able to lay his Astro down and then pick it up on his knee agian and keep on racing... would have liked to have seen that ;D
