Author Topic: Plastic Fuel Tank  (Read 4869 times)
Offline Stewart Allen
Plastic Fuel Tank
« on: January 15, 2009, 03:44:39 pm »
OK this is what I am planning to do with some Yamaha plastic tanks to try & get the transfers to stay on.
Clean tank (can any advise best method to clean inside) ?
How do I get residual fuel & oil vapors out of the plastic ?
Coat with blue lightning sealer
Sand & smooth the outside (do I need to do anything special on the area I am going to put the transfers) ?
Fit transfers, are the ones with holes the best ?
Do you think this process will be successful ? If not give me the benefit of your experience.
Thanks & Cheers
Stewart
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
Offline E74
Re: Plastic Fuel Tank
« Reply #1 on: January 15, 2009, 04:40:54 pm »
In my experience the only ones that ever stay on have a metal film within them like these
http://stores.ebay.com.au/SpeedandSportGraphicReproduction/WICKED-TOUGH-Vintage-Graphics.html
Offline Viper79
« Reply #2 on: January 15, 2009, 04:51:58 pm »
I have had Zing graphics on my RM 400 for over six years now with out them lifting, and I have had the perforated graphics on my YZ 465 for around three years now.
With the RM, I flushed the tank with prepsol (wax and grease remover) and then washed it out with soapy water four or five times and then left it sit full to the brim with soapy water sealed air tight for three days to remove any vapors that may still be in the plastic. Then I cleaned the area for the graphics with wax and grease remover or nail polish remover and applied the graphics to the tank with the soapy water still inside the tank. Then I let it sit and cure for a few days before emptying the water out.
The YZ was a bit different, I sanded the tank back for weeks so most of the vapors would have escaped in that process so it was just a quick wipe with wax and grease remover over the freshly sanded smooth tank and on they went.
Something I have always done with them is to drain all the fuel out of the tanks and leave the caps off after every use.
Regards
Rob.
Regards
Rob.
« Last Edit: January 15, 2009, 05:11:57 pm by Viper79 »
QA50 KO, XR75 K5 Race bike from VMBA days, XR400R1, CRF450R3, RM400T, DR650SE with off road adventure mods, MX360A, YZ400D, YZ465H, IT250H, 1985 Jawa 897 Slider, 2016 Jawa/GM Slider
Offline E74
« Reply #3 on: January 15, 2009, 06:39:20 pm »
where did you get the YZ H Tank Decals?
Offline Viper79
« Reply #4 on: January 15, 2009, 07:39:12 pm »
« Reply #5 on: January 15, 2009, 07:40:10 pm »
have just done a YZ 125K with the wicked tough ones and doing the same as Viper and looks good.
 ;D
Rossco
Offline E74
« Reply #7 on: January 16, 2009, 12:47:37 pm »
Good tips Viper79
here is some good information on fitting decals
http://home.alphalink.com.au/~asg/articles/decfit.htm
« Last Edit: January 16, 2009, 01:02:45 pm by LWC3077 »
« Reply #8 on: January 17, 2009, 01:01:39 pm »
what soapy water do you use? CT18 truck wash?
Offline Viper79
« Reply #9 on: January 17, 2009, 01:20:21 pm »
Morning fresh dish washing liquid.
Rob.
BigBossGraphics
« Reply #10 on: January 19, 2009, 01:20:16 am »
None of the mentioned procedures are foolproof and any fuel left in tanks for a period of time will attack any adhesive either on the sticker itself causing the adhesive to be gooey or more commonly between the sticker and the laminate producing bubbles - always use a company who can provide a base material (printed media) with a compatable over laminate. All too often 2 entirely different products are thrown together which are ill suited to say the least and when they are put on plastic fuel tanks absolutely useless.
If you want your decals to last on a plastic tank you have to put in the hard yards by removing fuel after every ride as already stated.
Now another way to do it is to lay it straight over the oem tank stickers (on modern bikes that is) i really dont have the answer to what the oem kits are made of does anybody else?
Lisa
www.bigbossgraphics.com
« Reply #11 on: January 19, 2009, 01:46:20 am »
i think most modern bike manufacturers have given up on stickers on tanks. most now have the stickers on the radiator shrouds.
lms6201
« Reply #12 on: January 19, 2009, 06:42:36 am »
i don,t know if anyone will like my new approach , i had a local signwriter print me up some sets from the cheapest vynil , worked out to be about $5 for a tank set , when they get tatty , a new set goes on
