Author Topic: RM 125/250 & PE 175 triple clamp spacing  (Read 3519 times)
« on: January 09, 2009, 07:49:21 pm »
I need to find out an accurate measurement of fork leg/triple clamp widths on some of these models with 38mm forks
82-84 PE 175
79-83 RM 125
79-82 RM 250
Did they just bore out the earlier 36mm clamps to 38mm (if so i can just go by my 36mm clamps, but if they are different spacing, going by the 36mm triple spacing will muck all my measuremts up) or is everything spaced out wider?
To work this out I just need to an accurate measurement beween each fork leg or inside edgeof  each fork leg hole in the triple clamps and then just add on 38mm and that will give exact centre to centre fork leg spacing.
Does anyone know if the triple clamp widths on 82-84 PE 175 are the same as the 81-83 RM 125? I thought I could work it our from zedder and alpha-sports but the hubs are different part numbers. If the hubs and axle spacers where same on PE 175 as on RM then I would have said yes the triple clamps are the same
« Last Edit: January 09, 2009, 08:08:19 pm by LWC3077 »
Re: RM 125/250 & PE 175 triple clamp spacing
« Reply #1 on: January 09, 2009, 08:34:59 pm »
As I see it  Rm 250 T and PE T/X have the same centres   180mm
« Reply #2 on: January 09, 2009, 09:34:34 pm »
ok just gotta find out what the full floaters clamps are now. Brent do you have a set of these?
Offline Grunter215
« Reply #3 on: January 10, 2009, 08:57:03 am »
My RM125X is the same..180mm
« Reply #4 on: January 10, 2009, 09:41:08 am »
did you have 142 between tubes then add on the 38= 180mm?
Offline Grunter215
« Reply #5 on: January 10, 2009, 10:07:50 pm »
Yeah 142+38 and between air cap valve centers. Also measured PE400=144 +36 =180.....same centers.
« Reply #6 on: January 10, 2009, 10:15:39 pm »
very good, that matches what ive got/found out. for a while i wasnt sure if they were 179 or 179.5mm center to center but it seems logical if they made the spacing an even number. just want to know what the 82-84 PE 175 is now, but by the sounds of it they will probably be 142 between inside of legs and 180 centre to centre, but i dont want to do any guessing
if its not too much trouble can you put a photo of the RM 125 triples x/z/d on here? if its too much trouble for you dont worry
thanks
Offline brent j
« Reply #7 on: January 11, 2009, 02:30:35 pm »
I've only just read this post, I checked a set of spare 82' PE175 clamps and they are 180mm between centres with 38mm tubes.
« Reply #8 on: January 11, 2009, 04:07:34 pm »
ok thanks Brent and everyone else, that has helped me a lot.
