Author Topic: Monoshock adjustment  (Read 2460 times)
« on: January 05, 2009, 11:46:25 pm »
OK all you Yamaha gurus - I nearly have my motor sorted on my YZB - next is front and rear suspension.  Will get Walter to help out with a set of PD valves for the front but can somebody tell me how you adjust up the rear if it is toooooo soft for my rather handsomeley (!) proportioned frame?  Are they just adjustable on nitrogen pressure in the accumulator?
thanks
Catch ya!
Rossco
Re: Monoshock adjustment
« Reply #1 on: January 06, 2009, 12:25:25 am »
The early monos seem to run really high pressure - and with that big thick shaft (tee hee), it makes a difference.
Pretty sure they've got a 46mm piston, so Walter should be able to help you out with a modern valve piston, a stiffer spring and then you can run lower gas pressure (ie: basically turn it into a modern shock).
YSS
« Reply #2 on: January 06, 2009, 07:39:39 am »
You are on the money Nathan , Springrate is No 1  and then you make the damping to suit.
Keep in mind those shocks and forks where made for  pre 80 tracks  and blokes of 75 kg . pumping up shocks and forks is definitely only a bandaid , but not a cure.
