Author Topic: PE Speedo Drive  (Read 2357 times)
Offline pmc57
PE Speedo Drive
« on: January 02, 2009, 09:00:31 pm »
Who know's how to get the speedo drive mechanisim (cable end) out of a PE front brake backing plate?
Offline frostype400
Re: PE Speedo Drive
« Reply #1 on: January 02, 2009, 09:04:23 pm »
ask Leith pm him heres his forum name lwc3077 thanks Michael.
1971 tm400 and PE's
Re: PE Speedo Drive
« Reply #2 on: January 02, 2009, 09:23:22 pm »
first clean all the gunk out. you then should see a redish/brown plastic/fiber bushing with 4 little cut outs. i use long pointy pliers to engage with 2 of the 4 cu outs and then unscrew the bushing. be carefull as there are small shims under the bush ( dont loose them). once you get the bushing out the worm drive will come out. the rest is straight forward
« Last Edit: January 02, 2009, 09:29:32 pm by LWC3077 »
Offline pmc57
Re: PE Speedo Drive
« Reply #3 on: January 02, 2009, 10:43:32 pm »
Got it Leith, many thanks.
I also had another hub off I think was a PE175, but this one had a small location screw coming in through the side of the backing plate to retain the threaded bush. It was that small that I'd missed it first time, it wasn't till I checked the exploded view on Alpha that I realised that there was actually a screw there. Slippery little suckers.
Re: PE Speedo Drive
« Reply #4 on: January 03, 2009, 09:10:59 am »
yes some have a locating screw. ive seen that on my TS hub but not PE 250/400. you can also get a little bit of metal and make a 2 pronged tool
« Last Edit: January 03, 2009, 12:38:30 pm by LWC3077 »
