Author Topic: Spark plug blanking bolt  (Read 2363 times)
Offline vmxken
« on: December 30, 2008, 10:09:08 am »
Hi - I need one of those special 'bolts' that blanked off a second spark plug hole in the head.  It is for a 1/2" reach plug hole.
Ken
Re: Spark plug blanking bolt
« Reply #1 on: December 30, 2008, 10:28:23 am »
I may have one in an old DT1 head Ken. l'll have a lookie and get back to you.
Offline frostype400
« Reply #2 on: December 30, 2008, 12:01:58 pm »
is that like on the some of the suzuki ts's i dont have one but i thought that was for a second plug and acted like an emergency plug if your main one shot itself you could switch the lead and have a fresh plug although that can sometimes look a bit ugly thanks Michael. :)
1971 tm400 and PE's
« Reply #3 on: December 30, 2008, 12:28:37 pm »
14mm bolt with plug washer/copper washer should do the job
« Reply #4 on: December 30, 2008, 12:58:11 pm »
Got a brass one with sealing washer some months back from the local plumbing and gas fitting supplies Ken for $3.
« Last Edit: December 31, 2008, 12:05:53 pm by Tim754 »
Offline frostype400
« Reply #5 on: December 30, 2008, 03:13:18 pm »
yeah you could get a brass 1/2 plug you could get a washer anyway and if you want it shorter just cut with a hacksaw is there a reece or tradelink near you probably 3$ for a brass plug they will help with something half inch thanks Michael. :)
1971 tm400 and PE's
