Author Topic: 490 clutch  (Read 1550 times)
Offline DG 26
  • 250H 125D it490 looking for pre75bike
490 clutch
« on: December 27, 2008, 10:23:40 pm »
Giday all  ;D
looking for a inner clutch hub for a IT490K :o ? 1 of the spring posts has departed to much power ? :D
Thanksdon
lms6201
Re: 490 clutch
« Reply #1 on: December 28, 2008, 07:24:48 am »
normally from holding a post to undo the hub nut ,  if u still have the post u may be able to screw it back on from the back with a csk 6mm bolt , run a tap right through the post , csk the back of the hub , if u are worried about balance , stick another screw in an opposite post , if the post is missing u can turn one up , use loktite on the retaining screw
Offline DG 26
Re: 490 clutch
« Reply #2 on: December 29, 2008, 08:37:07 am »
Thanks Ims6201
will give it a go  ;)
