Author Topic: Rear sprockets.  (Read 1586 times)
Rear sprockets.
« on: December 27, 2008, 05:59:35 pm »
Various and assorted. I dunno what they're from, but if they don't find new homes soon, then they get scrapped.
The majority of them have a 130mm centre hole, and a 150mm PCD. I thought they were Kawasaki, and that Kawasaki hadn't changed for years, but my '84 KDX has 134mm centre hole. Maybe Kawasaki did change?
Anyhow, they're the gold one, the two on top of the gold one, and the two to the right of the gold one. Had SFA use, and are nearly new. 52T alloy, 50T steel, 49T alloy and 48 tooth steel. I also have two extra, more worn of these sprockets, both alloy (51 and 49T, if my memory serves me) (not in pic because they're already in the scrap pile). $10 each, or $35/lot.
The one at the top right is a brand newie. NFI what its from. Has a ~15mm offset (kinda like a YZ125A/C, but its definitely not a YZ125 sprocket). 47T. $10?
The ones down the left of the pic are all in excellent, (barely) used condition.
The top one (5-holes) has a ~110mm PCD, 44T, takes a 530 chain and is steel. $5.
The middle one (4-holes + surface rust) has a 100mm PCD, takes a 520 chain. Not for sale if it turns out to suit a SL100/CT125/XL175. $5.
The botton one (4-holes + black) has a ~90mm PCD and seems to take a 530 chain. $5.
Or you can have the whole lot for $45, if you want them.
Nathan.
04000 23847
