Author Topic: what are these wheels off  (Read 5178 times)
Offline paul
« on: December 23, 2008, 10:02:20 am »
Re: what are these wheels off
« Reply #1 on: December 23, 2008, 10:04:11 am »
a motorcycle   :D :D :D :D
sorry couldn't help myself.  ;D
YSS
« Reply #2 on: December 23, 2008, 10:05:00 am »
Most likely they are of a motorcycle  ;D
« Reply #3 on: December 23, 2008, 10:07:47 am »
was thinking of :"What state are you in"
sorry paul hope some one has the answer  :-*
YSS
« Reply #4 on: December 23, 2008, 10:11:21 am »
You are running a bit early Paul , wait till eveyone hade their X mas drinks  ;D  Then you should get good feed backs .
Offline paul
« Reply #5 on: December 23, 2008, 10:14:03 am »
i was just going through stuff out side and im not sure what they are for
« Reply #6 on: December 23, 2008, 10:24:33 am »
Jeez Paul, Too easy on the top one. It's off a pre 1970 Maico........You should have known that. ::)
Next down appears to be a Yamaha conical. We need a better shot of the other side to be sure.
No idea of the rear wheel. Yamaha maybe?
« Last Edit: December 23, 2008, 10:28:16 am by firko »
Offline paul
« Reply #7 on: December 23, 2008, 10:37:34 am »
well thank s mark  i was looking for that one
« Reply #8 on: December 23, 2008, 10:39:35 am »
It's all part of the service.
Offline paul
« Reply #9 on: December 23, 2008, 10:40:46 am »
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #10 on: December 23, 2008, 10:54:49 am »
conical front i don't think is yamaha, it looks to be from the brake side but not from the smaller/conical side.
the rear looks to be yamaha, common to DT250 monoshock as well as some YZ's,TT's {i think :)}
"flat bickie"
Maico31
« Reply #11 on: December 23, 2008, 11:09:31 am »
Paul that front wheel looks like Bultaco and the rear looks a bit like Suzuki RM A or B.
Doc
« Reply #12 on: December 23, 2008, 12:10:32 pm »
The rear be an RM A/B/C unit from '76-'78 but the others I'm unsure. Easiest way with jap stuff is look for markings inside the hub that at least indicates manufacturer, the max ID in mm should also be a vague indication of capacity the bike the wheel came from ;) as for the Bulty and Euro stuff, I have not the foggiest idea ::)
Offline RM Ted
« Reply #13 on: December 23, 2008, 12:52:03 pm »
REAR IS OFF A RM C MODEL. THE A AND B HAD A SMALLER HUB I THINK....
1978 rm 125 x 3
1981 rm 125
1987 rm 125
« Reply #14 on: December 23, 2008, 03:35:45 pm »
oops.....Now I see that conical hub from another angle it's definitely not off a Yamaha. My vote now goes to Bultaco. I should just stick to what I know which means top one is still off a square barrel Maico. How much do you want for it Paul?
