Author Topic: PE175 - what model is it?  (Read 17475 times)
Offline mboddy
  • Canberra
« on: December 20, 2008, 08:40:26 pm »
I have just been given a twin shock PE175. The frame number starts with 206.
What model is it? The Pure Enduro site doesn't mention 206 frame numbers.
Vinduro Penrite Team
gerpster
Re: PE175 - what model is it?
« Reply #1 on: December 20, 2008, 09:08:43 pm »
Are you sure its 206 and not 200??? 200 appears to be PE175 1980...    ???
Offline Noel
« Reply #2 on: December 20, 2008, 09:14:36 pm »
http://www.suzukicycles.org/photos/identification/FRAMELIST_1200-pix-wide.jpg
yep my geuss is an N 1980
T's 1981 start 207........
Noel
EDIT
your right ,got confused with the Rm T being a twin shock and the RM   X  firsts of the floaters but PE 'X' twin shock
or I can't read a chart ::)
« Last Edit: December 21, 2008, 10:39:02 am by Noel »
« Reply #3 on: December 20, 2008, 09:38:34 pm »
no it cant be a N and a 80
C=78
N=79
T= 80
X = 81
whats the full frame number? a photo will also help ID. the PE forum also has other frame/engine number charts.
if its got a black steel swing arm its 78
if its got black steel swing arm with snail cam chain adjusters its 79
if its got alloy swing arm with alloy bash plate its 80
if its got alloy swing arm with extra frame rails instead of alloy bash plate its a 81
thats the easiest way to tell, assuming parts havent been changed.
« Last Edit: December 20, 2008, 09:43:39 pm by LWC3077 »
Offline mboddy
  • Canberra
« Reply #4 on: December 20, 2008, 10:49:04 pm »
Thanks guys.
It has an alloy bash plate and I think it has an alloy swing arm.
It gets delivered on Tuesday.
Been a long time since I had a Suzuki!
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #5 on: December 21, 2008, 03:39:02 am »
see the FAQ at http://cid-407d7ef0965d3991.skydrive.live.com under Pure Enduro
year   model    frame        engine
1977   250 B  100001       100001
1978   175 C  100001       100001
       250 C  18647        18666
1979   175 N  107290       107298
       250 N  23045        22632
1980   175 T  200001       200039
       250 T  200001       200001
       400 T  100001       100001
1981   175 X  207590       207611
       250 X  204153       204199
       400 X  103457       103465
1982   175 Z  212209       212332
1983   175 D  215372       215401
1984   175 E  216788       216799
Offline mboddy
  • Canberra
« Reply #6 on: December 21, 2008, 08:43:19 am »
Other than the bash plate, what is the difference between a T and a X?
« Reply #7 on: December 21, 2008, 10:08:44 am »
i will have to get back to you on that, once i remember what they all are, there are quite a number of things. i will do it a little later today.
« Reply #8 on: December 21, 2008, 11:05:13 am »
These are the main differences on the PE 175 X compared to PE 175 T (81-80)
Frame –six days bars instead of alloy bash plate, extra muffler mounting hole, little skid plates under vertical down tubes near foot pegs to stop those rails getting hooked up on logs etc because of no bash plate. Construction of steering head is welded together assembly that is much stronger that the one piece assembly previously used. Better steering stops.
Cylinder – exahaust port 1mm lower
Different head gasket = different compression ratio
Carburettor – jetting changes
CDI- different
Rear fender – larger tool bag platform
Front fender -  I don’t know what difference is
Taillight – different shape and construction
Muffler bracket – different
Tank/side cover stickers – X has white Suzuki and 175 on top of 3 blue stripes
Thicker piston rings
Stronger piston
Exhaust pipe – better sound deadening material
Rims -  stronger alloy, different nipple hole size
Spokes – thicker, stronger
Chain guide -  T has 2 rollers, X has 1 roller and 1 nylon block, alloy plates also different.
Muffler -  different
Air box boot hose clamps – different
Cylinder head rubbers.
there probably is a few more things im sure. Possibly different air box lid on Australian models (different size hole in lid) not 100% sure on that though.
« Last Edit: December 21, 2008, 11:09:09 am by LWC3077 »
Offline mboddy
  • Canberra
« Reply #9 on: December 22, 2008, 10:18:32 am »
Offline mboddy
  • Canberra
« Reply #10 on: December 24, 2008, 10:59:02 am »
The bike is now in the shed.
It doesn't have matching numbers but they both start with 206.
« Reply #11 on: December 24, 2008, 11:20:47 am »
they didnt have mayching numbers. yes its a 1980 175 T
