Author Topic: Fitting stickers  (Read 2054 times)
carbyman
Fitting stickers
« on: December 17, 2008, 09:30:12 pm »
Any tips for prepping the fuel tank on my 83 kx250 before i fit new decals i have rubbed it with wet and dry polished it and brought it up the best i can get it
just dont want the decal to fall off to quick
Re: Fitting stickers
« Reply #1 on: December 17, 2008, 09:44:17 pm »
good scrubbing with detergent to remove polish residue and clean with de-wax. dont leave fuel in tank all the time. possibly look into fitting blue lightning tank liner.
Offline E74
« Reply #2 on: December 17, 2008, 10:16:54 pm »
where do you buy blue lightning taner liner in Aus?
« Reply #3 on: December 17, 2008, 10:22:05 pm »
im not real sure. there were some guys trying to get it for their PE tanks. i will ask if they had luck getting it out of the states.
BigBossGraphics
« Reply #4 on: December 29, 2008, 06:23:11 pm »
I presume that the tanks are not plastic but these are the instructions we give out with all our tank stickers -
*NOTICE: CERTAIN BIKES REQUIRE THEIR SHROUD GRAPHICS TO BE APPLIED DIRECTLY ONTO A PLASTIC GAS TANK. PLASTIC GAS TANKS ALLOW FUMES TO PASS THROUGH, WHICH CHEMICALLY REACT WITH THE ADHESIVE ON THE VINYL. WE USE A VERY "HIGH BOND" ADHESIVE, IN ADDITION TO CUTTING "SLITS" INTO THE PIECES BEING APPLIED TO THESE TANKS, TO HELP ALLOW THE FUMES PASS THROUGH. BUT THIS ALONE WON'T STOP THE BUBBLING EFFECT THE FUMES WILL PRODUCE. WHAT YOU NEED TO DO, AND NOT JUST WITH OUR GRAPHICS, IS FULLY CLEAN THE AREA WHERE THE GRAPHIC IS BEING APPLIED OF ALL PETROLEUM PRODUCTS AND SEAL THE TANK  WITH A CLEAR COAT. FROM OUR STUDIES AND SPEAKING WITH OTHERS IN OUR INDUSTRY, THIS WILL HELP IN 90+% OF THE CASES.
« Reply #5 on: December 30, 2008, 09:58:05 pm »
Use a steel tank. Plastic tank + stickers = bubbles  and loss of stickers, been going like this since motorcycle year dot. Carbyman follow BigBossGraphics instructions but don't fret if they come loose, you are not doing anything wrong.
« Last Edit: December 31, 2008, 09:34:53 am by Tim754 »
