Author Topic: Malcom Smith Fuel Tank  (Read 2445 times)
Offline pmc57
« on: December 14, 2008, 08:24:17 pm »
Does anyone know where I can get a new fuel tap grommet to suit a 70's vintage, Malcom Smith plastic fuel tank? It's a stepped style of grommet, small dia about 12mm large dia about 25mm with about a 8mm dia hole through. The fuel tap pushes in.
Must be new, I have a couple of old ones but they're perished and cracked with age.
« Last Edit: December 14, 2008, 08:26:42 pm by pmc57 »
Re: Malcom Smith Fuel Tank
« Reply #1 on: December 14, 2008, 08:37:01 pm »
yes. let me get back to you.
« Last Edit: December 14, 2008, 08:45:59 pm by LWC3077 »
« Reply #2 on: December 14, 2008, 08:45:29 pm »
specs are 1 inch Od base by 1/2 inch step with 3/8 ID
http://www.denniskirk.com/jsp/product_catalog/Product.jsp;jsessionid=Y1OVFXV2O4L3XLA0WTKSM4VMDK0NCIV0?store=Main&skuId=1828
http://www.denniskirk.com/jsp/product_catalog/Product.jsp;jsessionid=Y1OVFXV2O4L3XLA0WTKSM4VMDK0NCIV0?store=Main&skuId=182086
http://www.denniskirk.com/jsp/tpl/cmn/prodlist.jsp?store=Main&catId=311&leafCatId=31103&brandId=4100005&np=
these fittings from dennis kirk are exactly what you need. the rubbers are the same its just that one fitting is for 5/16 fuel hose and other is for 1/4 hose
you can use the fittings and a fit inline tap or use the stock tap in the rubber
or ebay seller east coast tractor
http://cgi.ebay.com/Wheel-Horse-Toro-Tractors-Fuel-Shut-Off-Valve-Bushing_W0QQitemZ360094607856QQihZ023QQcategoryZ82248QQcmdZViewItemQQ_trksidZp1742.m153.l1262
these rubbers are also exactly what you need
the ebay seller only ships to USA so i had to get a buyer in USA to help me out
these rubbers/fitting should also work on Can Am tanks
tank caps are also not a problem for the MS tanks
http://www.husqvarna-parts.com/catalog/item/3736880/5082934.htm
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=1834&store=Main&catId=311&productId=p1834&leafCatId=31106&mmyId=
« Last Edit: December 14, 2008, 08:59:42 pm by LWC3077 »
Offline pmc57
« Reply #3 on: December 14, 2008, 09:23:19 pm »
Wow LWC... you're a bundle of information, many, many thanks
Peter
