Poll
Hey Guys, is it race legal at club level to race with 125 'c' cylinder and 250a forks
std with mud catch rims
1 (50%)
not std with mudcatcher rims
1 (50%)
Total Members Voted: 2
Voting closed: December 19, 2008, 10:06:35 pm
Author Topic: yz125a ? did they come standard with mudcatcher rims plus race legals for cyl  (Read 3650 times)
Offline oldyzman
  • 250 two stroke!
yz125a ? did they come standard with mudcatcher rims plus race legals for cyl.
Hey Guys, is it race legal at club level to race with 125 'c' cylinder and 250a forks and tripples
The 125A came with Mudcatchers OR 'normal' Takasagos OR 'normal' DIDs.
250A front end is definitely legal.
125C top end is illegal, and easy to pick if you know what you're looking at, but unlikely to be detected/cared about at club level.
NAt do all the yz 125 parts fit/interchange until 77 ? or are there bits that cut off as in a-b-c, then everything else
No, but the top ends are all interchangable up until the 77 models. The difference is easy to pick: The early type have long 8mm studs coming out of the cases, whereas the later type have short 10mm studs.
The early type sandwiches the barrel between the cases and the head, compared to the later type which bolts the barrel to the cases, and then the head to the barrel.
Gearboxes have four basic types:
1. Early 5-speed (AT1, AG100, etc). One shaft for the gear lever.
2. Late 5-speed (YZ125A, twin shock DT etc). Two linked shafts for the gear lever.
3. Early 6-speed (YZ125C, YZ125X, etc). Two linked shafts for the gear lever.
4. Late 6-speed (YZ125D+ monoshock DT, etc). Back to one shaft.
You can't simply bolt a Type 3 box into a Type 2 motor as lots of bits are different diameters (input shaft, the rods the shift forks run on, etc).
I got a YZA 125 here and its got mud catchers although differant from the mx 250 style they seem thicker in the lip and a bit taller.  anyway they are on front and back and this bike is stock as a rocker
TM BILL
Mines got mud catchers i think there original :)
