Author Topic: rm125c  (Read 9154 times)
Offline caps 999
rm125c
« on: December 07, 2008, 09:03:12 pm »
anyone out there with a rm125c could you please take a picture of the top of your forks im reasearching something thanks in advance
MUGEN power
Doc
Re: rm125c
« Reply #1 on: December 08, 2008, 07:40:26 am »
Caps, if you're wondering about how much the fork should protrude through the top clamp I've seen various settings on differing bikes but I can tell you one thing for certain, the cap should NOT be flush with the top clamp. On my 400C 'when new' the machined groove on the leg lines up with the lower edge of the top clamp. Sliding them all the way in will achieve no extra travel and will result in extra slow steering. As a rule and after trial and error with the 400 I found if I slipped the clamps down till the bike started to get head shakes and then raised them about 5mm it was as good as it gets, ironically this was very near the standard setting of the groove just under the top clamp ::) slide the forks all the way up on any C model and you stuff the geometry and create a bike that just wants to plow straight in corners. Try it and see ;) I don't use any air assistance in any RM forks either out of interest.
Offline caps 999
Re: rm125c
« Reply #2 on: December 08, 2008, 09:39:35 am »
im doing some reasearch for the a by the look of things i need and extra inch of height in the front end after the fox shocks and i noticed the c had some slight extensions so i was thinking i could get some extra height from a set of those
MUGEN power
Doc
Re: rm125c
« Reply #3 on: December 08, 2008, 10:02:29 am »
in that case 125/250/400 all share the same diameter forks and the same cap extension bit so it gives a few more options. I see the caps for sale on ebay from time to time and usually very reasonably priced and very little interest ;)
Offline caps 999
Re: rm125c
« Reply #4 on: December 08, 2008, 11:34:10 am »
all i need is the extra inch just to compensate for the extra inch in the rear
MUGEN power
Offline BAHNZY
Re: rm125c
« Reply #5 on: December 12, 2008, 09:12:45 pm »
Caps,
Thanks to Snowy76 (Birko) i was able to build a real nice 125C. During the build i bought a few shitters from E-Bay and as a result i have a set of forks with the raisers that you are looking for. Whilst i need to keep the lower legs in the situation that i need to convert the Preton Petty No Dive you are welcome to the spacers and what ever else you need aside from the alloy lowers.
All i need to finish the bike (to be 100% accurate) is the proper C model plastic tank.
Bahnsy
Rod (BAHNZY) Bahn
Offline holeshot buddy
  • sunshine coast qld
Re: rm125c
« Reply #6 on: December 12, 2008, 09:16:26 pm »
hey caps reread your last post again ;D ;D ;D
follow me to first turn
Offline caps 999
Re: rm125c
« Reply #7 on: December 12, 2008, 09:58:38 pm »
hahaha got no problems in that departmant mate  :D :D left myself open there haha
MUGEN power
Offline caps 999
Re: rm125c
« Reply #8 on: December 12, 2008, 10:00:09 pm »
 Bahnsy  ill take the spacer do you need the chrome legs and are they any good
MUGEN power
Offline BAHNZY
Re: rm125c
« Reply #9 on: December 14, 2008, 11:19:09 pm »
Caps,
The chrome is shot to shit and would need to be re-chromed, taking a guess it wouldn't be worth the effort. You can either grab the complete forks and take what you need (alloy lowers aside) or i can send you just the extension caps. Your call.
Note: One of the caps is slightly damaged where either the handle bars would have rubbed on it or someone used the wrong size spanner at some point. If you have the rubber caps fitted you will never see anything.
Bahnsy
Rod (BAHNZY) Bahn
Offline caps 999
Re: rm125c
« Reply #10 on: December 15, 2008, 08:20:12 am »
ill just take the caps then mate will they work on a set of rm125b forks
MUGEN power
Re: rm125c
« Reply #11 on: December 15, 2008, 06:43:55 pm »
Tried to post pic, upload folder is full  ::) ::)
Re: rm125c
« Reply #12 on: December 16, 2008, 04:56:08 pm »
try this
Offline caps 999
Re: rm125c
« Reply #13 on: December 16, 2008, 07:12:33 pm »
there exacly what im after
MUGEN power
Offline BAHNZY
Re: rm125c
« Reply #14 on: December 21, 2008, 05:52:04 pm »
Caps,
Drop me you details and i will send them off to you.
Bahnsy
Rod (BAHNZY) Bahn
