Author Topic: wanted CR 450 engine bits  (Read 2688 times)
Offline crabman
« on: November 30, 2008, 05:01:07 pm »
hI
Can anybody help with a suggestion of where I can buy a 1981 CR 450 a new rod kit, piston,  rings and gaskets ? Please advise
Old and slow - and happy
Offline k2000x
Re: wanted CR 450 engine bits
« Reply #1 on: November 30, 2008, 05:42:38 pm »
i have a standard size piston n.o.s no ring but $80
Offline crabman
« Reply #2 on: November 30, 2008, 11:26:20 pm »
k2000x
I am interested, I assume it is a new piston, am I correct. Please send me your email details.
kristan
« Reply #3 on: December 01, 2008, 10:25:58 pm »
Ha ha ha ha ha! very funny!!! Sorry only kidding, just speaking from experiance. I have a used 2mm oversize wiseco if it is any use? The rings are still a stock item from wiseco. failing that you can bore it out to accept the standard 480.
as for the rod kit good luck.
do you have a series one or series 2 450?
also have you checked the crankcase where the clutch shaft bearing sits? this is a favorit for ging way ( as i found out)
America is your best bet for a rod
hope this helps
Kris
