Author Topic: Whatcha makin' ?  (Read 27429 times)
Offline pmc57
Re: Whatcha makin' ?
« Reply #45 on: April 22, 2009, 06:17:16 pm »
LWC
Got your pm, my MS tank is the same but in white. It's no good for me, sorry.
lc4
« Reply #46 on: April 22, 2009, 07:25:59 pm »
My XL250 Restoration
Offline pmc57
« Reply #47 on: April 22, 2009, 07:51:17 pm »
Lc4
Nice rebuild, I must admit tracking down the parts for a full resto is a daunting task, you've done a great job. I's a bit hard to tell via the pics, but are the rims and fork slider powder coated?
pmc57
« Reply #48 on: April 22, 2009, 08:11:10 pm »
rims look like the original DID matt silver annodized finish
lc4
« Reply #49 on: April 23, 2009, 05:16:43 pm »
Lc4
pmc57
Rims are powder coated ,wasn't my prefered option but the anodiser advised due to the heavy scratchs etc that anodising would be a waste of time.
Fork legs and hubs are bead blasted with two pack clear coat.
Took it down today and got a Blue slip now ready for rego  ;)
« Reply #50 on: May 03, 2009, 06:05:00 pm »
My toy:
Not quite finished, but I'm pretty happy with myself, seeing as it started the weekend looking like this:
A lack of spark was traced to a dead stator - funnily enough, the dead stator looks pristine, while the functioning one looks like its been dragged from the bottom of the ocean...
Plus lots of other fiddly stuff - cleaning out mud-wasp's nest from the carby, regreasing stiff steering head bearings, swapping tyres, etc.
Main things still to deal with are:
Cleaning up the pipe (stupidly, I have a brand-newie that I'm too scared to fit to the bike - you should have seen how long it took me to fit the NOS RHS sidecover. ::));
fitting a smaller front sprocket (this is a 15T one - apart from the gearing issues, it prevents me fitting the cover);
making a muffler;
Fitting a kill-switch;
and sorting out a rear guard/rear frame loop.
I haven't actually ridden it yet - it started second kick, and sat there idling happily - but then I remembered that The Boy was asleep inside so I shut it down. Apart from anything else, with no muffler its way too loud to go ripping around my suburban block...
There's a long story behind the bike and the bits, but the simple version is that I've been able to assemble a running bike that looks OK, for SFA money, thanks to Roger, 'the other Brent', Greg, Marty, Bruce and Nev - all top Aussie blokes (even if one of 'em is a Kiwi):)
« Reply #51 on: May 03, 2009, 06:11:52 pm »
it feels good to get some stuff sorted over a weekend, you get to go to work on Monday and start planning the next list of jobs. Plus you've still got tomorrow to go!!
I do like the works racing petrol cap
Offline pmc57
« Reply #52 on: May 23, 2009, 03:47:09 pm »
A few pics of the XL250 I've been working on over the last 6 months.
Before.
Offline pmc57
« Reply #53 on: May 23, 2009, 03:48:59 pm »
After
Offline vmx42
« Reply #54 on: September 27, 2010, 02:02:40 pm »
As projects get moved around the shed, the RM/PE175 comes out for some TLC.
As it stands it is running '84 43mm forks and twin-leading shoe brake, PE175 engine. '84 wheels front and rear.
It needs some new shocks, a small amount of frame welding and then a strip down for the cosmetics.
With a Preston Petty headlight and tail light it should look Vinduro enough. Much lighter than a PE, I hope it is worth the effort.
VMX42
« Reply #55 on: September 27, 2010, 09:10:10 pm »
mmmm....great minds think alike!
phil todd
« Reply #56 on: September 30, 2010, 04:11:32 pm »
I bought this IT200 in Zeehan, Tasmania - very original -it now has full road reg. Getting the speedo working again was a tricky one. Also swing arm shaft was seized in.
Yam  IT200
Phil
DR
« Reply #57 on: October 10, 2010, 10:17:09 pm »
Almost back to semi original but for me it's about a little individuality anyway ;) not to mention the outrageous cost of replacement stickers. No-one apparently has reproductions but I wasn't overly fussed in the originals regardless so all's good :) you can usually pick these up for a little over $500 running, more or less for better or worse. 32hp/110kgs and a cheap ride for pre'85 VMX or Vinduro ;)
« Last Edit: October 10, 2010, 11:02:52 pm by Doc »
TT
« Reply #58 on: October 10, 2010, 10:48:18 pm »
That's a bargain ride, Doc. I had one of those new in '88. For some reason.............   ::)
My Montesa is right to go so I'm currently working on the RS250 project. (Still....  ::) ) Not too different to VMX42's PE/RM thingy.  ;)
