Author Topic: Phantom ignitions  (Read 3135 times)
Offline JC
Re: Phantom ignitions
« Reply #1 on: November 24, 2008, 09:39:07 am »
Br,
If its any help, 74 Phantom Ign part # 123025M1
75 GP # 123025BM1
76 GP2 # 123025BM1
« Reply #2 on: November 24, 2008, 09:56:27 am »
Jc,
The seller doesn't know what phantom's they came in a mass spare parts lot.
They should fit all phantoms as the crank and stator mounts should be the same, I just don't know if the gp2 and 3's had a smaller flywheel to fit under the smaller case.
OSSA PHANTOM
« Reply #3 on: November 25, 2008, 08:14:30 pm »
 Th OSSA phantom ignition will fit under the newer style side cover as will a PVL ignition. The desert phanton ignition cannot be used on a MX phantom unless you swap the crankshaft halves, the desert phantom ignition will not fit under the newer style sidecover.
 I know that it is a bit pricey but a PVL or MZB ignition is probably the way to go. the swapping crank halves is costly and I wouldn't have done it had the MZB ignition with the lighting been available.
 When my desert phantom engine motoplat dies I'll be replacing it with an MZB, My GP3 engine uses
a PVL and my GP2 engine has a rebuilt Bradford motoplat.
« Reply #4 on: November 25, 2008, 09:16:25 pm »
Someone is claiming that neither of them suit a phantom (I think it might be Keith Lynas)
Anyone deny/confirm....hate to get something that's not going to fit, nearly as much as missing something that will fit.
OSSA PHANTOM
« Reply #5 on: November 25, 2008, 10:36:44 pm »
 The second unit looks to be a phantom MX unit which will fit under the new cover, attached is photo of a new stye cover I cast a few years ago.
« Reply #6 on: November 26, 2008, 08:16:38 am »
Did you sell one of these on ebay a few years ago?
I bought a homemade one...it was very well done.
OSSA PHANTOM
« Reply #7 on: November 26, 2008, 07:05:54 pm »
 Evo,
  Yes it was I. I had I had more funds I would have die cast them instead of sand casting. I keep a couple for my bikes and sold the rest to Alex Snoop.
