Author Topic: PE special tool and bracket  (Read 3345 times)
Offline frostype400
« on: November 17, 2008, 09:44:31 pm »
Hi would anyone have the bracket that holds the PE special tool near the top of the triple trees i am also after the genuine tool if some one has one lying around and if you have the band that holds it to the lower bracket also interested also dont care if its rusty or bent thanks Michael Ryan. :)
1971 tm400 and PE's
Re: PE special tool and bracket
« Reply #1 on: November 17, 2008, 09:47:34 pm »
Michael, go to the PE forum and look in the files section. There are CAD drawings of the tool brackets in there with all the dimensions taken from originals to show you you how to make one or simply hand it to a metal fabricator.
rubber bands are on ebay, i saw them 20 mins ago. its just a big o-ring. go to a bearing/o-ring supplier. they will be able to help
tool band here
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160298245564&ssPageName=MERC_VIC_RCRX_Pr4_PcY_BID_Stores_IT&refitem=150309165766&itemcount=4&refwidgetloc=closed_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m183&_trkparms=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D4
« Last Edit: November 17, 2008, 09:50:53 pm by LWC3077 »
Offline frostype400
« Reply #2 on: November 17, 2008, 09:49:49 pm »
No Problems can make one in metals at school id be doing something for once ;D thanks still after genuine tool thanks Michael. :)
1971 tm400 and PE's
« Reply #3 on: November 17, 2008, 09:52:30 pm »
tool is available from Motoduro, any suzuki dealer in australia or worldwide or on UK ebay. i think theres one on ebay now in Uk
Offline frostype400
« Reply #4 on: November 17, 2008, 09:59:57 pm »
Yeah i knew you could get after market ones may get one from dealer near me i printed the drawing still interested in buying real thing if someone has one thanks Michael. :)
1971 tm400 and PE's
« Reply #5 on: November 17, 2008, 10:03:41 pm »
aftermarket tools???? the one motoduro sells is genuine i believe. order the tool buy part number and you will get the right one.
Offline frostype400
« Reply #6 on: November 17, 2008, 10:11:34 pm »
I just assumed it was a reproduction I think i will ring the suzuki dealer tommorow to see if i can get one i have a engineering place just around the corner from me there probably a good candidate to make a very good holder thanks again Michael. :)
1971 tm400 and PE's
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #7 on: November 17, 2008, 11:46:14 pm »
Ban BLACK rims NOW
Offline frostype400
« Reply #8 on: November 18, 2008, 08:10:50 am »
Thanks although i should be able to get one from a dealer near me if anyone has the full setup im still interested. ill have the top bracket made from the metal place around the corner thanks Michael :)
1971 tm400 and PE's
