Author Topic: Removing dents with ice ???  (Read 11513 times)
Doc
Re: Removing dents with ice ???
« Reply #15 on: November 11, 2008, 03:48:27 pm »
only if one drinks it ;) personally I don't touch the stuff..my world is already too distorted :D
Offline caps 999
« Reply #16 on: November 11, 2008, 04:22:21 pm »
burbon mmmmmmmmmmmm  ;D
MUGEN power
« Reply #17 on: November 11, 2008, 04:29:04 pm »
Used ice to reduce and soothe lumps on thick head before .... nearly the same thing sorta ? maybe?  On petrol tanks etc bull..............
Offline Mick22
« Reply #18 on: November 13, 2008, 06:48:53 pm »
I just tried using ice to remove dents, ended up talking no stop to the tank for a few hours, did a bit of dancing and then punched on with the mig welder ;D ;D
« Reply #19 on: November 13, 2008, 07:01:24 pm »
Give to the myth busters ;D. I vote no ;).
Offline zorroz
« Reply #20 on: November 16, 2008, 02:27:07 am »
A mate filled his WR450F header with water (that had a big dent) and after leaving it in the fridge overnight came out good. Doen it again and nearly all came out.
« Reply #21 on: November 17, 2008, 09:00:25 pm »
It does work buttt, only for small pressure dents that air will pop out faster.
 tried it on a chamber once . In the chest freezer  over night and some of the dents popped out  before it blew the plugs out.
Water expands as it freezes  then contracts as it gets colder. Bit is, you have little or no control over the ice method where as with air  you have a bit more control and add heat and u can remove larger dents
OSSA PHANTOM
« Reply #22 on: November 25, 2008, 07:24:15 pm »
 This works but you cannot seal the tank or pipe, leave one end of the pipe uncapped or the tank  vented, fill it completely full stick it in the freezer. If you complete seal off the unit when the ice expands
it can pop the welded seams
Doc
« Reply #23 on: November 26, 2008, 02:42:15 am »
mmm, I reckon it will work too Ossa. I wouldn't think sealing the tank would be in the best interests and the control of this method could be had by controlling the amount of ice within and the directional forces it applies by the way the tank is positioned in the freezer. I still haven't got around to trying it ::) an RL tank is much longer than I'd anticipated ::) one can imagine what a crumpled mess the tank would look like if it were sealed and the ice allowed to melt :o oops :'(
« Last Edit: November 26, 2008, 02:46:10 am by Doc »
Quicksilver
« Reply #24 on: November 26, 2008, 05:21:51 pm »
Dont do it Doc................. Totally f*&ks the tank. I have a CR250m tank some clown tried this with. Damn thing wont even sit down over frame. Oh yeah it looks good and straight. Just useless except as a wall mounted display peice. It all puffed up. The passage in centre of the tank where frame sit has closed up a fair bit. It also leaks petrol around the welded seams.
« Reply #25 on: November 26, 2008, 05:41:13 pm »
The correct way to remove dents with ice ;D ;D ;D
« Reply #26 on: November 26, 2008, 05:49:40 pm »
What's the coke to bourbon ratio, looks slightly richer than the recommended 20:1 :o  In a schooner glass ??? I suppose church and school is out so it about that time.
 ;D
« Reply #27 on: November 26, 2008, 05:58:20 pm »
The ratio is always a hard one to nail, it always seems to get richer as the night goes on ;D
4RoBs
« Reply #28 on: November 26, 2008, 09:19:22 pm »
Hey Geoff, was the coke used to polish the header pipe after the dent came out???
Rob
« Reply #29 on: November 27, 2008, 06:13:36 pm »
No way rob, it's too expensive. I know Mythbusters did a show on this but it's much cheaper to clean things with petrol as it's cheaper than coke & bottled water (go figure).
